Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1880 continous paper jam error on screen
How to fix this error. what to do to make my printer back to normal. I clean and remove the jammed paper in my printer but still paper jam error message comes out again and again, every time i print a document.. and there is no printer reaction.
  • 1 more comment
  • yhatz_payat Mar 26, 2009
    i did always turn on and off my printer, but still nothings change. it cannot even feed paper.
  • Anonymous Mar 15, 2014
    canon printer mx410 has paper jams still after cleaning rollerr
  • Anonymous Mar 31, 2014
    paper got jammed in printer and after removing the jammed paper when i tried to print another document the paper got jammed again
    Problem Solver:
  • 3 Answers
First you turn off your p.
Posted on Mar 26, 2009
SOURCE:
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Office Equipment & Supplies
What is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
Apr 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
PRINTING PROBLEM WITH CANON IP1880
Shut the printer off. Than unplug it's power. Than unplug the USB/data cable. Wait about ten minutes. Allowing printer to reset it's self. Go to pg. 37 of your manual & follow instrctions for cleaning. Connect the power cable, the usb/data cable & turn on the printer. Test printer for error paper jam (light/display message). Canon's web site for drivers, updates, software & guides. PIXMA IP1880 is the iP1800 series.
When web sites loades you must choose your operating system from the drop-down menue.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=14991
Problem not corrected? Uninstall printer software. Re-start PC. Re-install software. Re-start PC & re-test.
Hopefully you will not need to uninstall & reinstall.
Feb 11, 2008 | Office Equipment & Supplies
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA iP1800 InkJet Photo Printer Logo
2,578 people viewed this question
Clive
Clive
old marine
old marine
Ekse
