Question about Sun Cobalt Qube 3 (CBT-Q39302PAU) Web Server
Problem When i turned on the equipment
Hi everybody I have a qube 3 unit and when i press the on button of the unit and see the LED Staus screen the only thing appeared are the following lines : =================== Nothing more appeared or change. This happen to me this morning and i have no idea if this is a permanent problem or not. If the worst scenario occured, how can i extract my data from the hard drives?. Thanks in advance
    Scholar:
  • 47 Answers
You can try removing the hard drives as a las resort and connect them via either SATA or EIDE to your PC. I'm not sure what you set as a RAID level, but if it's RAID 1 (mirroring), the data on both drives should be identical. Is it still under warranty? If so, I'd suggest getting Sun on the phone to get it repaired.
Posted on Sep 09, 2007
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Hi my panasonic CS-PS18NKQ is not working,timer indicator keep on blinking.
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display. Note: Display only for "- -". (No transmitting signal, no receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
When you have the error code, you can narrow down the problem.
Feb 04, 2015 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
I have a laserjet m3035 no display on screen 2 LED light not work
Shut down the printer and remove the power cord. Leave the unit off for a minute or two. Replace the power cord.
  • 2 Press the "Power" button on the printer. Hold down the "Select" button on the printer as you turn the unit on. Continue holding the "Select" button until the LED lights on the printer flash once and then remain on.
  • 3 Use the up arrow to scroll to "New Maintenance Kit." Press the "Select" button to reset the maintenance kit counter.
  • Oct 20, 2011 | HP LaserJet M3035 MFP Printer
    Have a jumbo remote with no code search button also only programs 3 devices tv'vcr&dvd
    I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
    Jul 02, 2011 | Innovage Jumbo Remote Control
    I need NOMA N1508 manual.
    answer 1 Function and operation
    1 - This timer has 3 working modes
    a - Auto Mode(AU)
    b - Auto and Temperature Control Mode (AC)
    c - Manual Mode (LL)
    Press "MODE" button and the LED display will cycle through these three modes.
    2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
    3 - There is a bettery backup that can retain programs for about 1 week after power outage.
    Operation
    1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
    2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
    a - The time interval for this product is 15 minutes
    b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
    c - After setting the time, press the enter button and the LED will display current time setting.
    d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
    3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
    a - Auto Mode
    Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
    - Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
    - After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
    - Press "ENTER" button to return to normal time display mode.
    - The program indicator will be turned on after the ON time and ending time have been programmed
    - Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
    - In case you want to modify the setting repeat step "a".
    *** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
    Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
    - The timer activates the load only when the folloewing two conditions are met:
    1 The temperature is below -10
    2 The program on time p is reached
    For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
    - The program indicator will be turned on after the ON time and the ending time have been programmed.
    - When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
    C - Manual Mode
    Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
    - In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
    - To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
    4 Output indicator
    1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
    2 - In Manual mode the outpur indicator turns red when loading is deactivated.
    3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
    To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
    Jan 11, 2011 | Sport & Outdoor - Others
    I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
    RTFM: Page 13:
    "A demonstration of the display is shown if you have not set the
    clock. You can reduce the power consumed in standby mode by turning the demonstration off.
    While the unit is on:
    Press and hold [–DEMO] until “NO DEMO” is
    displayed.
    Each time you press and hold the button:
    NO DEMO (off) DEMO (on)
    This is a 24-hour clock.
    The example shows how to set the clock for 16:25 (4:25 p.m.).
    1 Press [0/I] to turn the unit on.
    Press [CLOCK/TIMER] to display “CLOCK”.
    Each time you press the button:
    CLOCK>>PLAY>>REC>>Original display
    Within 5 seconds
    Press [SET].
    Press [TUNING (Up or Down)] to set the time.
    The time display can be changed in one minute units by tapping
    the buttons, and quickly by holding down the buttons.
    Press [SET].
    The time is set and the original display is restored."
    Or under Troubleshooting Page 38:
    "The display starts up even after the unit is turned off.
    The demonstration feature (–DEMO) is on. Turn it off if it is not required."
    If you need the manual go to
    http://audio.manualsonline.com
    register and get it for free.
    Mar 25, 2010 | Technics SC-EH780 CD Shelf System
    Sun Cobalt Qube 3 Power Supply gone bad
    Search eBay.
    I just found a Sun Cobolt Qube 3 on eBay in good condition for $80.
    You could buy it and use it for spare parts.
    If this helps please vote for my solution.
    Aug 19, 2009 | Computers & Internet
    Masterplug tvrc4n 4 in 1 remote control/sanyo
    http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
    If none of the codes work then we have two other solutions:
    1. Searching For Your Code
    If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
    If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
    1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
    2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
    3. ENTER 9-9-1 (two blinks on the remote)
    4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
      Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
    5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
    2. Learn the buttons from the original
    Line up your original remote and the head-to-head before completing thefollowing steps.
    1. PRESS and HOLD the SETUP button until the red LED flashes twice.
    2. PRESS 9 - 7 - 5, the red LED will flash twice.
    3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
    4. PRESS the button that will receive the learned function, the LED will flash rapidly.
    5. PRESS the button on the original remote to be learned.
    Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
    To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
    More help for programming your remote can be found here:
    http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
    Hope that helps! Should you have any further questions,please feel free to post them here.
    Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
    · Set the "Mode Switch" to TV.
    · Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
    · Enter the 5 digit Code above.
    · Try your new code and tell us how it worked!
    You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
    hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE;
    Sep 23, 2008 | Philips Magnavox Learning Universal Remote
    No signal on screen
    first of all do you see anything on screen if you press menu.if you do then wate for menu to go away then press source button on top or remote should see in one corner vid 1,2,ext ext if you don't see anything on screen this chinesse tv is not working (WHAT A SUPRIZE) you need to see some graphic's on screen tosee if backlight is working or your in the same boat as everybody else that owns one of these tvs no fix no help from company. GOOD LUCK DOC
    Mar 06, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
    Sun Cobalt Qube 3 (CBT-Q39302PAU) Web Server Logo
    73 people viewed this question
    Top Sun Computers & Internet Experts
    Robin Hill
    Robin Hill
    k24674
    Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
