Question about Dell 2300MP Multimedia Projector
My acer lap top will not recanize the projector when i press the fn plus thef8 keys
When i press the fn and f8 keys my laptop my screen wll apear shortly then i will loss signal
    Brigadier General:
  • 6,966 Answers
Re: my acer lap top will not recanize the projector when...
Hi, Try lowering your laptop's resolution (Display Properties) to 1024x768 (or even lower like 800x600), before fn + F8. You can also try lowering the Monitor's screen refresh rate (60Hx). Another setting you can check is Advanced Settings tab or button and check settings for projector (instead of TV). If it works in the lower settings, you can try moving the settings higher until it quits again. If the above does not fix your problem, you may need to re-install your graphics/video driver. Hope this gives you an idea. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 24, 2007
0 characters
3 Points
My Proxima Ultralight SV1 projector no longer projects what's on my Dell laptop computer screen. It's been working normally until this week. It still projects "searching" but seems...
Press Fn key and F8 key to turn On external monitor output in laptop so projector will get video output of laptop.
Hope this will help.
Aug 03, 2011 | InFocus Proxima UltraLight SV1 Plus...
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
Unable to play live tv from lap top to projector
Is it just the live tv or the laptop in general you are not getting a signal from? Using 15 pin VGA cable correct from laptop to projector?
When booted to projector, on laptop, select "FN" key and either F5, F7 or F8 depending on your laptop. Look for the monitor logo on the F keys. This is telling the computer that you have hooked up an additional external monitor (the projector). Once will send image to projector, twice will display on both, a third time will return to just image on laptop.
Jun 17, 2010 | Sanyo PLC-XU51 Multimedia Projector
No signal
are you sending the signal to the projector. FN+CRT/LCD button key simultaneously. if you do this 3x you will get the following. no image at projector image at laptop scree, image at projector and laptop screen, image at projector no image at laptop scree,
Jun 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
I can't get my laptop to appear on the Hitachi CPRS55 projector
Look at your laptop keys and be certain that Fn + F8 is the right combination. Could be Fn + F4, depending on your laptop.
If the key combination is OK, your VGA cable (from the projector to the laptop) could be faulty.
Hope this helps.
Jan 18, 2010 | Hitachi Performa CP-RS55 Multimedia...
No signal
switch your lap top first and the projector second----check input is assigned to computer-------press fn key with conjunction of f4 or f5 or f6 or f8.
May 09, 2008 | Optoma EzPro 739 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Multimedia Projectors
I cannot ger the projector to project the image on the laptop. I have held down the Fn Key and F8 to no avail
connect the projector to your laptop and restart the computer in that way it would recognize the presence of your projector... ;)
Nov 18, 2007 | Multimedia Projectors
Dell 2300MP Multimedia Projector Logo
88 people viewed this question
Top Dell Multimedia Projectors Experts
Electro Med Services...
Are you a Dell Multimedia Projector Expert? Answer questions, earn points and help others
