Question about Dell 1100MP Multimedia Projector
Dell 1100mp "Temp" Light
The projector powers up for about a minute or two then shuts down and the "Temp" light will flicker 4 or 5 times. I first thought the fan was out, but I can hear and feel the fan blowing on startup.
  • 2 more comments
  • bocestech1 Nov 07, 2007
    Having the same problem. Projector runs 30 seconds to 2 minutes and shuts down with a flashing temp. light.
  • Anonymous Apr 19, 2008
    • EL PROJECTOR PRENDE NORMALMNETE PERO SE APAGA A LOS TRES MINUTOS, EL TESTIGO TEMP TITILEA,
  • Anonymous Sep 22, 2008
    where can i get it fixed?
  • jjbeta77 Jan 06, 2009
    yep...same problem but I'm here in Thailand with little confidence that I can get this fixed unless someone can give me some advice how to fix myself. the sad fact is that I haven't even put 15 hours on this projector!! I opened the lamp door and blew everything clean but still no go. thanks.
I had the same problem and fixed it today. The fan is 70 x 70 x 20mm. I could not find the exact one, but 70 x 70 x 15 works just fine and I was able to find that fan at a Micro Center store for $8.99. The fans should be blowing air out from the front of the machine, not blowing in on the lamp.
Posted on Jul 08, 2009
Posted on Feb 10, 2008
  • 38 Answers
This is a common problem with these projectors. There are actually 3 fans in the unit, 2 of which commonly fail. If you replace the fan with another one not exactly like it the unit will still shut down after a few minutes with a fan fail error. (blinking temperature light) I may be interested in purchasing your dead projector. Please email me at nalexandrov251 (aT)gmail.com and we might be able to work something out.
Posted on Dec 09, 2009
I ´VE CHANGE THE FAN, BUT I HAVE A QUESTION. DOES IT HAVE A SPIN DIRECTION? IT BLOWS OR ASPIRE?
IT´S WORKING BUT I´M AFRAID IT´S NOT THE SPIN DIRECTION
Posted on Nov 05, 2008
Hope this help someone,take out the bulb for 5 minutes,while out spray dust off inside,then place bulb back in place.this is only an temporily fix,until you can get an fan replacement
Posted on Jun 06, 2008
Mine does the same thing! I took it apart and found that one of the fans were not working. I can't find a replacement fan. Could you tell me the company you used to fix your unit?
Posted on May 28, 2008
  • Mark Monschein
    Mark Monschein Dec 09, 2010
    Same here,I found a 3 pin 3 wire fan the same size but it still shuts off with a temp light flashing ugh !
Where did you get the fan?
Posted on Mar 27, 2008
We have several of these projectors and this is a common problem. The cooling fan that directly cools the bulb dies. Since the warraty is expired on them we have gone through hell and back to get them fixed. We found a company that will fix them but no one will sell us the parts.
Posted on Mar 20, 2008
I'm having the same problem. It was working fine for a while. Not sure what changed.
Posted on Feb 18, 2008
SOURCE:
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Dell 1100mp projector
need to buy the right projector lamp for dell 1100mp
May 28, 2008 | Dell 1100MP Multimedia Projector
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
Wont start up
Pls clean the filters and check the lamp by opening the lamp cover. If lamp looks okay in all aspects then send the projector to any engineer to check the ballast unit of the lamp.
Viren
+919814903739
Nov 26, 2007 | Dell 1100MP Multimedia Projector
Overheating
Please clean the filters for the air and the air circulation path for cooling the lamp.
This will definitely work, pls also check that the condition of lamp is okay or not as sometimes lamp goes with the ballast unit of the lamp and that damages the new lamp.
Viren
Nov 06, 2007 | Dell 1100MP Multimedia Projector
Dell 1100MP Multimedia Projector Logo
3,268 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
