The thermostat shows 88 but the air temp (using another thermostat) is 84. How do I calibrate the Honewell to read 84???
In the thermostats setup there can be a calibration mode however this is a chasing the gragon type of endeavour that rarely ever culminates in thermostats jiving with another, they typically are off plus or minus 3-4 degrees anyways as they are not designed to maintain too narrow of a temperature differential or the furnace will short cycle or run too often & stop in short order.
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
SOURCE: EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
SOURCE: I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
SOURCE: My thermostat shows wrong numbers! Not possible temps but 5 to 20
Hi, your thermostat is reading celius instead of F.Degrees. There should be a switch under the cover or in the program for you to change back.
Shastalaker7
SOURCE: Honeywell CT500 Electronic Thermostat showing
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
