Question about Samsung HCN653W 65" Rear Projection Television
Samsung hcn653w power surge
Hello, a loud crack of thunder , then my tv went dead, no blink of the lights, was on a power strip with other items that were unaffected, please help.
You say that they replaced the Mainboard 2 times on this model? I had the same exact model and they came out and replaced the Mainboard and 2 other parts 4 times. Under the lemon policy warrantee at Bestbuy, I am now (finally) able to replace the TV with a Mitsubishi WD-65733. This TV is a "LEMON" if you can, "GET RID OF IT!" It's a piece of "JUNK!"
Posted on Sep 19, 2007
  • 398 Answers
If the set went dead during a storm and will not power up at all, first try unplugging the set and waiting an hour or so, and then plug it back in to a working outlet and try turning it on. If the set still will not respond, your power supply has stopped working and should be serviced by a qualified tech familiar with Samsung projection sets.
Posted on Aug 28, 2007
6ya staff
SOURCE:
Was watching my samsung LN55C630 TV and all of a sudden it just went dead. nlo picture and no sound,also the power light went out thats normally on when the tv is off.
Check the circuit breaker first for power to the outlet it is plugged into. If it is in a power strip then make sure that the reset is hit on that. I sounds like you had a line surge for some reason. If all else fails there is a fuse on the power board in the TV. Check to see if that is blown. If not check for black burn marks on the power supply board. Could have blown that altogether.
Mar 05, 2014 | Samsung Televison & Video
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
Possible power surge earlier today. TV will not
If your TV was plugged into a power strip with a surge arrestor, the power strip may need a reset (if there is a reset button) or replacement (those surge arrestors are only good for so many "hits". Try plugging the TV in elsewhere.
If it was not plugged into a surge suppressor, it is time to call a repairman.
Oct 07, 2009 | JVC AV-20220 TV
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
