Televison & Video Logo
Anonymous Posted on Aug 24, 2007
Zenith SY3572DT TV - Zenith SY3572DT TV
  • 2 more comments
  • Anonymous Aug 24, 2007
    I need help with adjusting the color for this new ciruct board.
    I belive i need a walkthrough in the service mode to correct this color problem.
    i was also in service mode and screwed up the tv more, and now it will not turn off when plugged in.
    ok. I think i finally figured out that i cannot get the color green to come up. any suggestions?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 326 Answers
  • Posted on Aug 24, 2007
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
326
Questions
Helped
150217
Points
632
Hello, please check your email. You should have received the service manual. Please check if there is a heating for G cathode (inside the picture tube neck there should be 3 light sources). If one is missing you should replace the picture tube. Best regards, Arpi
2answers
I have a 3 in 1 Magnavox remote. I need to program to a zenith converter box. I don't know the codes.
Digit Zenith TV Converter Box Remote Codes
212
254
267
357
454
457
557
657
757
857
955
957
991
4 Digit Zenith Converter TV Box Remote Codes
1415
9910
5 Digit Zenith Converter Box TV Remote Codes
01414
51415
1helpful
Will not turn on anymore
download this 12mb full service manual from my ftp sight,request it at [email protected]
Tv repair
Hi; i have a 36 inched color television and it has a horizontal line going arcross the TV ,but it sounds like it is on but do not show a picture.Zenith Model# Sy3572DT and Serail# 781-4171582 I would like to purchase a part to replaced
the old one could you help me.......
Thanks
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
Junk TV & Poor service
zenith agreed today to replace mine.
4helpful
2answers
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
No picture
vertical output bad or bad connections on main module
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
ZENITH ANALOG TV, CRT DEFLEXION YOKE
No Longer Available thru part distributors....you might try
E-BAY......T.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
