Question about Fuji FinePix A340 Digital Camera
Screen reading memory card not initialized
I bought a new memory card for the camera -- an Olympus XD M2GB. When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos. It's the ve of my sister's wedding and I want to take lots of photos - help please! Many thanks. Kristina
  • 2 more comments
  • ladyterror Jun 29, 2008
    i have a fuji finepix a340 digitial camera when i bought a new card by olympus the card read not initialized what can i do in order for this card to work with my camera
  • nicahleigh11 Aug 12, 2008
    I've had the same exact problem listed below, but when I hit "disp/back" and "on" the top of the screen reads "Filmware Upgrade" and the middle of the screen reads "Card Error".... does this mean I have to do the upgrade as well?
    Thank you.
  • lamb25 Aug 16, 2008
    screen reading memory card not initialized
  • created4this Dec 16, 2008
    I have the same error message showing, but this is my original card which has worked for years. I was doing some downloading and uploading to the card, which I also do all the time for years. When I was done, I put the card back in my camera only to find the error message: Card Not Initialized
    I have a Fuji FinePix 3800
    What happened to my disc and what can I do to fix it?
The trouble with trying to format large cards of 1Mb or 2 Mb is that in order to do so you need your original card or a card that currently WORKS. I have one of 16 Mb. Go to Fujis web help page and download the firmware fix "FinePixA340" to your PC. Run and extract the data file "FPUPDATE".Now you have to put this file onto the old card. I pasted it so it was "beside" the DCIM folder ( NOT the next one down 100_Fuji folder or it won't work). To copy and paste you may have to connect the camera to the PC or use a XD card reader/writer via a USB port. Having done that, put the card back into the camera if you used a XD writer and switch off the camera. For the next bit make sure your batteries are good or connect to a power supply. Hold down Disp/Back button and THEN turn on camera. It should have detected the new firmware data file. Follow the simple instructions-say yes and let the data file load--takes a few minutes. The camera should say the new version !.22. Now that the firmware has been updated , you can now format your NEW LARGER cards 1 or 2 MG. So take your old card out ,put the new card in and format. It worked sweet as a nut for both 1 and 2 MG. The trick is to use a card that already works,load firmware file onto this , update file onto camera, then format a larger card. Its what they don't say exactly that causes frustation. Happy formating campers
Posted on Dec 04, 2008
  • 31 Answers
There are two types of xD card - one are simple, and the other are M-type cards, these works faster, but not supported in older cameras. i believe A340 will not work with M-type cards, so you just have to buy another card, also see manual specifications on how big the card can be, i know most of the old cameras only support cards 'till 1GB, simply because on the moment they were made, they didn't have 2GB back then, so these 2 things to consider before buying a new card
Posted on Aug 24, 2007
I believe that the A340 can only handle a 256Mb card, as I have tried a 512 and a 1Gb and the camera couldn't handle either.
Just my 2 cents...
Posted on Jul 15, 2008
This is an answer from somebody else but i followed the steps and now my camera is working fine. ignore some of the sentences in fujifilmusa website. you must use new batteries when you do the steps.
First, while holding down the "disp/back" button, press the "on" button. The camera should now be showing you the firmware version you have on your camera. If it says 1.22, then you are all set. If it says 1.00, then you will need to update it. Go to
http://www.fujifilmusa.com/JSP/fuji/epar...
click on
"1. Free FinePix A340 Firmware (camera control software) Update Ver.1.22"
Follow the instructions there.
Once you have 1.22 on your camera (or if you do already), plug the camera into your computer.
Plug in your camera to your computer and turn it on. Go to your camera in "my computer". Right click it and select format.
Posted on Jun 15, 2008
2 Suggested Answers
SOURCE:
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
I have a olympus fe-220 using a memory card xd M2gb. i went and bought a new card but its not exactly the same its a xd M+2gb. will i still be able to use the new 1 ? whats the difference between the...
Yes, you can use the XD M+2GB card in your camera. The M+ card is a faster one. The following website gives you more on it.
http://www.olympusamerica.com/cpg_section/cpg_xd.asp
"The Type M+ xD-Picture card is compatible with the Type M card in all cameras and is 1.5 times faster than the Type M card. The increase in speed may be useful in sequential shooting of digital stills and in the recording of high-density video with Olympus cameras."
Good luck.
Jan 08, 2011 | Olympus FE-220 Digital Camera
help me i also have the same problem please email me how you fixed the problem? [email protected]
mahalo's
Feb 17, 2009 | Fuji Finepix Z20fd Digital Camera
I just bought an Olympus mju 820 and it keeps telling me that the memory card is full but i have only taken 4 photos. I have put in the xD picture card and it still won't allow me to take any more photos....
try to change the mega pixel rating and see,,,,
did you format the memory card initially before using that brand new??
also see if the storage is set to memory card and not to the main memory
Oct 11, 2008 | Olympus Cameras
It sounds like your XD card is corrupted. How and why i couldn't tell you. You will need to get the pictures recovered from the card using a special software (image recovery software, can down load for free from some web sites, or some companies can try and do it for you) and then try and format the card in the camera. DO NOT FORMAT THE CARD BEFORE YOU RETRIVE YOUR IMAGES. If you do all traces of the images may be lost.
All the best and happy snapping.
Aug 20, 2008 | Cameras
New Memory card not working
To RangerGuy999
Just read your problem so obviously missed your daughter's vacation but here is my answer.
The firmware update you need is available here....
http://www.fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=879916&prodcat=710740&sscucatid=664260
It wil give instuctions on how to do the update & the precautions you need to take.
hopefully this helps
FlashyBits
Aug 15, 2008 | Fuji FinePix A340 Digital Camera
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 31, 2008 | Fuji FinePix Z2 Digital Camera
    Mar 07, 2008 | Fuji FinePix A330 Digital Camera
    Fuji FinePix A340 Digital Camera Logo
    1,012 people viewed this question
    Top Fuji Cameras Experts
    Ekse
    Steven Wander
    Steven Wander
    Azam Ali
    Level 1 Expert
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
