Question about Kenmore 45081 Front Load Washer / Dryer
Washing machine My Kenmore washing machine would fill with water but would then stop. Would not agitate. So I poked around the questions / answers here and catriver? gave the advice of pulling the tube off the back of the control panel and blow into it. I did it and it worked. Or so I thought. I got it to drain (Moved the knob to spin) and drained the water out. I put everything back together and let it run through a short cycle. Patting myself on the back until the wife told me that the garage was flooding. Now the washing machine will not stop filling with water...?
  • almost Aug 25, 2007
    I did indeed make sure the tube was back on but alas, still overflowing. Tube is clear also. So I need to replace the pressure switch? I also broke the door switch but I just put 2 popsicle sticks in it and screwed the ground wire down. Thus, bypassing the safety device. Is this bad for the board or will cause any problems down the road. Lastly, I had a heck of a time getting the thing apart. Is there a tool or an easier way than taking the whole thing apart from the back?
    President:
  • 878 Answers
Almost, I hope you put the tube back on. This goes on the pressure switch and the pressure switch determines when the tub is full according to the load size. I don't know what post you read, there's been so many. You have a couple of things to check here. First, make sure the hose going from the pressure switch to the tub is clear. Blow through it. If it's clear it's possible you have a faulty pressure switch. If that tube is not secure on the switch and the tub you will overflow. If the pressure switch is faulty, you can overflow too. Catriver.
Posted on Aug 24, 2007
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Kenmore model 119 24622300 Heavy duty 2 speed washing machine....The machine was in mid wash cycle and completely stopped. Although we have emptied the clothes and water out manually (it would not drain),...
    the first three is 110 on your model number,not 119.lift the lid up around two inches and close it down,do this a few times,if you don't hear a clicking sound the lid switch is broken,part number 3949238.if that's ok when the washer is in spin does the motor run,if it does you broke the motor coupling,this is located behind the motor,let me know what you find and if you could answer the questions i asked i can help you out better
    Oct 08, 2010 | Kenmore Washing Machines
    My washing machin suddenly stop while I was doing laundry when it gt fill with water
    After water filled, the machine will enter agitation mode. It stopped since the mechanism to engage the agitation to one direction of motor turning is not engaged. It is a helix nut to lock in the direction of motor turning (motor has 2 direction : one is for agitating and the other is for spinning). It is worn out and needed replacement.
    Sep 20, 2010 | Kenmore Washing Machines
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    Kenmore top loading washing machine model 4021092, keeps filling
    It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
    http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
    May 03, 2010 | Kenmore Washing Machines
    Kenmore 70 Series washing Machine won't stop filling with water
    filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
    Apr 27, 2009 | Kenmore 22422 Top Load Washer
    Machine doesnot agitate or drain once filled with water
    it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
    Apr 24, 2009 | Washing Machines
    Kenmore washing machine won't stop filling with water
    yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
    Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 45081 Front Load Washer / Dryer Logo
    57 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
