I'm running SBS 2003 premium with two active Token Ring adapters and an Eicon
Diva BRI 2m ISDN Server card. I want to install a dial in connection to
internet and E-Mail-Server. When starting the internet connection wizard it
stops with the message: One Networkadapter must be active. Please start the
Network configuration and activate one adapter. Running the Pop3 connection
manager and starting connection to my internet provider manually, Exchange is
able to recive Mails. Two adapters because SBS want a second adapter.
Uninstalling one is the same error.
The Server is installed with standard MS settings. RAS, Fax, DHCP, DNS etc.
are running without problems, E-Mail internal without problems.
Did anyone know a solution for my problem?
Rating: 0%, 0 votes
Regards,
Marina
Microsoft SBS-MVP
"geouser" <geou @discussions.microsoft.com> schreef in bericht
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Windows-IP-Konfiguration
Hostname server1
Prim??res DNS-Suffix GEOFink.local
Knotenpunkt unbekannt
IP-Routing aktiviert Ja
WINS-Proxy aktiviert Ja
DNS-Suffixsuchliste GEOFink.local
Token Ring-Adapter LAN-Verbindung des Servers:
Verbindugsspezifisches DNS-Suffix:
Beschreibung Olicom Token Ring-PCI/II-16/4-Adapter
(OC-3137)
Physikalische Adresse 00-00-83-69-72-FD
DHCP aktiviert Nein
IP-Adresse 192.168.16.2
Subnetzmaske 255.255.255.0
Standardgateway
DNS-Server 192.168.16.2
Prim??rer WINS-Server 192.168.16.2
Token Ring-Adapter Netzwerkverbindung des Servers:
(OC-3137)
Physikalische Adresse 00-00-83-29-FE-A4
DHCP aktiviert Nein
IP-Adresse 192.168.16.3
Standardgateway
Trying other setting I lost the possibility sending Mails
Thank you for answering.
Rating: 0%, 0 votes
Your external nic has to be in a different IP range, it will have to have a
gateway that is pointing to your router and WINS is not needed on the
external nic. Also, NetBIOS over TCP/IP should be disabled on the external
nic.
Regards,
Marina
Microsoft SBS-MVP
Post a New problem for Olicom Token-Ring PCI/II 16/4 OC-3137
Email this problem
