How do I enable wpa encryption? I have an intruder connecting to my router. Can I block them somehow? Thanks.
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
WPA2-PSK
(data encryption TKIP or AES)
WPA-PSK
WEP (256
Bit) - Weak, but better than no encryption
WEP (128
Bit) - Weaker, but better than no encryption
WEP (64
Bit) - Weakest, but better than no encryption
plz do rate the solution if got help
Thanks. I don't have device security in Vista (that I saw), but I searched in CP and found what I was looking for. Your instructions are much appreciated, kvgopi!
