My original fasco motor 7190-1186 u90B1 is replaced by a fasco d236, but when I received the d236, I noticed the wiring diagram was different. The original motor has two brown wires going to the cap, two to the supply and 1 ground. The new motor has two wires to the cap and three speed wires (H, M, L). How do I wire this new motor in?
Is this a water heater blower? Or HVAC?
Post question on water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
I do not have HVAC resources
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: REPLACING CENTRAL HEATING PROGRAMMER LS112
Yes, you are dropping 1. Is that wie=res required? or wire terminal location indentifier numbers? Follow your directions and then question them if you don't get desired results. Good luck
Crud, this got posted in waterheaters, should be in something like air conditioners. Sorry. If someone knows how to change the category, I'm all ears :-)
yeah, I screwed up and put this in water heaters. Didn't know how to change the forums. I have some tests I'm going to run, will write what I find. Thanks
