Question about Indesit WA 115 Front Load Washer
Indesit w101 front loader
Power light comes on but nothing happens .I can reset it ok and open the door
  • Anonymous Dec 02, 2007
    I have a W101 also, the dial on the right just clicks round and round no matter what i do, i have reset it numerous times but straight after resetting it starts this odd behaviour again.
    I beleive the action itself is some form of error code but should just need resetting, although this hasnt been the case for me.
    Can anyone help?
  • 67 Answers
Poss brushes worn out
Posted on Aug 31, 2007
SOURCE:
A few weeks ago the machine (IWDC 6125 S) started to flash against all the options at the top. I had turned it on an off and it was working OK. Just yesterday the door was shut, but the machine would not...
The only quick suggestion I have is to unplug it for several minutes and see if it resets. If not, without any other indicator, the only thing I can think of is the door switch, which should be a fairly easy fix.
Jul 04, 2017 | Indesit W 123 Front Load Washer
Indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
May 05, 2010 | Dishwashers
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Indesit wia111 no lights come on when switched on at powerpoint
Make sure you dont have it set to soak. if you click the timer one click at a time, does the wash/mach. do anything like wash:spin:drain etc. check that door latch for power out once closed. difficult to diagnose without all the facts
Jan 27, 2009 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Indesit WG635 TP power light on but not working
sorry program board my friend replace.
Thanks J
Feb 01, 2008 | Indesit W 123 Front Load Washer
Washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Nov 20, 2007 | Washing Machines
Maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Aug 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
How can i open the door on my washing machine it wont open
Remove machine's upper cover and you will have an access to the door lock unit. Don't forget to disconnect the power cable first! Good luck!
Aug 01, 2007 | Indesit W 123 Front Load Washer
Indesit WA 115 Front Load Washer Logo
348 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
