Question about Sega Genesis Console
Sega console am getting no response from control pad
  • graper Aug 24, 2007
    tried cleaning connections. changed controls&game cartridges; didn't help
    Problem Solver:
  • 13 Answers
If there is no response it sounds like there is a bad connection between console and controller. I would clean the connectors. If that doesn't work take the controller apart and make sure the wire is connected well to the board inside the controller. You can try to unconnect it and reconnect it. Clean the board inside, that might help.
Posted on Aug 24, 2007
How to fix a stuck button on game gear
This is an easy fix. Open the Game Gear by removing the back panel. Take off the front panel, and the buttons and pads will come up. Remove the pads and buttons and clean the pads, buttons with alcohol, to remove the dirt and gunk around the buttons and pads . When finished replace the cover. Test the system. If the pads do not respond to the game, the pads may be worn down and may need replacing. There is a website called Ifixit that has the parts for the Game Gear. Go to ifixit.com to get the parts. Or go to Sega.com for help. Also call 1-800-872-7342. This is the number for SEGA . Hope this information helps.
Jan 10, 2014 | Sega Game Gear Console
Control pad
Control pad's are generally all or nothing devices, they either work or they're dead. However with a console of this vintage there are a few things that can cause this kind of issue and therefor a couple things you can do to try and resolve it. 1: Clean the serial ports and plugs (the ports and plugs that connect the pads to the console) with an air duster. Air dusters are cans of compressed air with a long nozzle and are available from most computer, electronics and hardware stores. Clean both serial ports even if you're only using one. 2: if cleaning doesn't work try unplugging the power cable, removing the console's casing and touching a hot soldering iron to the base of each of the pins that connect the serial ports to the PCB (Printed Circuit Board) in tern to re-solder them without using any extra solder, if you find that you do need more solder be sparing. You can see a pictorial guide to disassembling a Sega Genesis here www.takeitapart.net/archives/sega-genesis/ click the pictures to see a larger image. Lastly if you know anyone else who's in to retro-gaming swap a control pad with them to see if your pad works on there Sega Genesis and there pad works on yours. If you find the pad actually is dead it's not the end of the world, there are a few around on popular auction sites, retro gaming sites and specialist game stores pretty cheaply.
Aug 23, 2007 | Sega Genesis Console
Sega genesis
thye are IR and you have to point them at the console wen you are playing
Dec 06, 2013 | Sega Dreamcast Controller
I can not get the controller to work to set the date and time
Make sure that the controller is plugged into the left most port on the console. Try using the D-pad for navigation. If you do not get any response from the controller, you may need to purchase another one.
Mar 06, 2011 | Sega Dreamcast Console
Controller Ports Not working
try blowing real hard into the controller port, sometimes dust gets inside there
May 24, 2009 | Sega Genesis Console
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
Controller port 1
i had the same prob a few years ago when i had my frist one probly dry jonits
Aug 04, 2008 | Sega Genesis 2 Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Control pad does not work
You should definately check the jacks for your console, that includes the controller's male and the console's female jack. If you have to, go ahead and wipe them clean with some alcohol, letting some drip in and let them air out. Its possible that some stuff has dripped inside the console's power or reset switch that caused problems with your Sega. You could try and go ahead taking the console apart, checking the terminals and stuff inside for mositure. Also, you shoudl try a new contol pad, as it definately didn't win any awards for its reliabitly.
Sega Genesis Console Logo
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Norman Worley
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
