Question about Motorola Mobility RAZR V3
Lcd heat 2
Venkzzz's about the lcd heat gettin hot (v3i), and drained my battery fast even new. your previous answer it's the water that cause my phone heat. can you be specifice what parts i should replace it? is it the cable flex for v3i? hope only that one.! or any part must be replace like silicon (IC) chip. you are really correct that water mess my phone! i remember when i caught with the rain. but before that happened I experienced the phone when you flip up to use it, sometimes i can experienced white screen and i will closed the flip and open it again and it will work... thanks so much venkzzz's hope you will reply again.. God Bless you.
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have it fully service about the phone heating you need to have the mainboard replaced.
Posted on Feb 24, 2008
Battery draining quickly
the hot water will be at least 1500 watts and that is half of most gensets
have a trailer electrician check out the current draw for the battery
May 21, 2017 | Heating & Cooling
Heating problem due to water enter
remove battery immediatly dry inside of phone and battery with hair dryer on a very low setting.might work doubt it mobiles and water don't mix never know you might be lucky
Jun 28, 2015 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
Bike battery drains fast, bike seat & area below seat gets too hot to sit on
It sounds as though the seat pan might be coming into contact with the battery and thus causing the seat to heat up and drain the battery all at once. My question would be if the battery was recently replaced and an incorrect sized battery was used. If battery isn't under the seat pan itself, check for wires that might have insulation damage that could cause a short and draining the battery. Also some people have installed heated grips on their bikes, maybe the switch for that isn't off when not in use and causing a drain.
Apr 22, 2013 | 2003 Yamaha V Star Classic
When hot tap is turned on there is a banking noise from boiler.Have had new pump fitted and have domestic hot water and central heating.Noise continues, but not as bad as before.When heating switches on...
try by draining tank. it may have sediment build up in it. heres how. go to www.ehow.com/how_5544402_drain-hot-water-tank.html this site will explain it better. have a good day! Sediment can drift into recirculation lines, jam open check valves, and cause the recirc pump to stick until it burns out. it causes noise, sometimes enough noise to annoy, or even frighten, people if the tank is inside a dwelling. The noise is caused by small amounts of water under the sediment layer turning to steam bubbles, which then collapse violently.
Feb 18, 2011 | Water Heaters
Heats up drains battery fast
heats up?do you mean the unit itself heats up fast?if that so.you unit has a short circuit inside on it thats why your battery drains so fast...,but if its not,the problem is on your battery.Not even a battery can charge is meaning that your battery is still good.If a battery has defect or let me say it is already weak,it will not already stored a longer life of a power.,becoz if that so,the current or well known as the ampere is already goes down than the given specification when it is new..and thats the reason why it is already fast draining.
Oct 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Radiator heats up when running a shower.
Your boiler is overdue for a service.
Combi boilers are unlike regular boilers in that they have quite a few moving parts, it's vital that these are serviced annually if you want the boiler to remain reliable and to avoid expensive failures.
In your case, the diverter valve has most likely failed. Normally, when the heating is on this senses when there's a demand for hot water and temporarily diverts the primary hot water circuit to feed the domestic hot water heat exchanger. When the demand for hot water ceases the primary hot water circuit is diverted back to the central heating heat exchanger. The valve has a number of moving parts including a rubber diaphragm which can wear out and split and moving shafts which can seize.
When the valve fails it can leak and also can divert hot water to the central heating heat exchanger when hot water is used. The reason that only the highest radiators in the system are affected is probably because the failed valve does not necessarily cause the central heating pump to activate and circulate the hot water throughout the system (it does on some boilers though). If hot water is introduced into a cold heating system it will rise via convection to the highest points in the system like an old fashioned gravity circulation system which was unpumped.
Call a heating engineer out as soon as possible; I'm not going to advise how to do the repair yourself as gas appliances MUST be serviced by qualified persons only for reasons of safety. If you're lucky then the valve simply needs cleaning up and a few new diaphragms plus other minor seals and rings. If it's gone too far then the valve and possibly the manifold it's attached to will need to be replaced.
In the UK the part alone typically costs between £100 to £200 depending on whether it's just the valve or the manifold as well. The diaphragm kit typically costs up to around £15 and is routinely fitted when the boiler is annually serviced, and a new valve will already have new diaphragms fitted. For a routine service expect to pay for up to two hours labour (many can be done in one hour), but if the valve/manifold have failed it will be longer as one failure often causes other parts to need further inspection/repair.
I hope that I've helped you today, if so please return the favour by rating my answer.
Jul 10, 2009 | Whirlpool Aquatic Millennium VII -...
Overheat/battery drain
Hello dogwillhunt,
It is normal for a two-way radio to generate some heat, especially during extended periods of long talk time. Consumer two-way radios tend to be much more susceptible to this because they tend to be constructed out of materials that do not dissipate heat very efficiently, such as polycarbonate and plastic. Periods of heavy transmit times also use additional power, causing the radio’s batteries to run down more quickly and require replacement or recharge. Use of the display backlight feature can generate additional heat and run the unit out of battery power even more quickly.
If the radio is heating up excessively and burning through batteries (pardon the pun) in situations where you are not using the LCD backlight excessively or transmitting for long periods of time, this may be indicative of a problem with the unit that would require service, such as a short or defective component. If such is the case, I would recommend contacting the manufacturer.
Agent Ken
Go Ahead. Use Us
Apr 07, 2008 | Garmin Rino 120 2-Way Radio
Lcd heat
it seem like water must have entered the set get it serviced
Aug 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
