Question about SanDisk Sansa e260 MP3 Player
SanDisk e260 Problem
I ordered a new USB cable and a new charger because the other ones were junk. I plugged it into the computer, nothing happened. The same thing happened with the charger. Someone gave me advice to get a new battery for it. I tried it and it turned on, but it didn't solve my problem yet. Please give me a solution! Thanks!
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
SANSA FUZE CHARGER
The Fuze charges through its USB connector. You can plug it into a powered USB port on a computer or a USB charger plugged into a wall outlet. You may already have one of these for your cell phone.
If you need a connector cable, you may order one here. One AC adapter is here.
Mar 16, 2012 | SanDisk Sansa e260 MP3 Player
Where do i get a charger for this i can't find the charge can i buy one at a store like walmart or do i have to buy it on the internet.
You can use any AC-to-USB charger. For my Sansa, I use one that came with a cell phone.
Alternatively, you can plug the Sansa into a computer's powered USB port.
Sep 04, 2011 | SanDisk Sansa e260 MP3 Player
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
I cant sync or charge my sansa e260 mp3
If you recently bought this product, then I am really and truly sorry. These e200's are all really unreliable. If your warranty has no yet expired, I suggest calling SanDisk and requesting a new one : / you'll have to send yours in and they'll send you another one free. Such an inconvenience.. I had it happen numerous times...
Jun 18, 2009 | SanDisk Sansa e260 MP3 Player
Charger & headset not working
u can use the USB cable to charge it directly from ur computer or u can buy a universal USB charger from any shop.
Feb 12, 2009 | SanDisk Sansa e260 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Battey
or
-Tha Mp3 Doctor
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Sansa USB and Charger Problem
hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Aug 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
