Question about Whirlpool Washing Machines
Washing machine is leaking from the bottom the washer is a whirlpool model LSR7233D
    Problem Solver:
  • 7 Answers
Check the pump, it's right up in front after you get the cover off. This unit is about 15-18 years old. The pump housing is plastic and eventually begins to leak around the input shaft. They're relatively cheap, about $30, and can give you another couple of years out of the machine if you want to try to fix it.While you're in there you might want to inspect/swap-out the flexible coupling betewen the motor and transmission. That's about $25 and it's pretty easy if you're handy.
Posted on Nov 24, 2010
SOURCE:
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Washer leaks out the bottom of machine need access to inside of machine
A small amout of water leaks underneath on the left side of the washer-they think the tub ring is causing the problem. Whirlpool Cabrio
Mar 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
There is a leak in the bottom of our washing machine
If the leak is from the front, you will need a pump. If in the rear check the water valve and the inlet hoses. Also if a lg leak check the hose from the pump to the drain grommet. They sometimes split.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leak coming from the bottom of my washing machine
HELLO TOM DID YOU CHECK TO SEE IF YOUR DRAIN VALVE IS LEAKING ?normaly there located at the bottom of the washer inside the back cover.
Apr 01, 2009 | Whirlpool LSN2000LW Washer
Amana model TAA500L1 washing machine repair
you have the seals out of the washer. with washing farm clothes and the sand and grit sitting on the bottom of the machine right on top of the seal and bearing they went bad. i suggest that you by a whirlpool washer there seals are up higher then any other machine. amana, maytag ge are not good for farm wahers sorry to inform you.
Feb 15, 2008 | Washing Machines
Washing Machines Logo
227 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
