Question about Maytag MAV7600 Top Load Washer
Drain hose leak
Drain hose has sprung a leak. Need to replace it. Washer comes from factory with drain hose attached. Need to know how hard it is to disassemble washer and replace drain hose.
  • 3 more comments
  • msb357 Sep 04, 2007
    Hi Krazytech,
    Thanks for your help! Had a little trouble figuring out how to remove the front panel, but when I got that figured out, it was pretty easy going. Thanks very much for your help!
    Cheers,
    Mason
  • Anonymous Mar 22, 2014
    Please help me
  • Anonymous Mar 27, 2014
    our washer leaks when we use xl load setting but is fine when we use the other load settings. All the hoses and drain are all in working order.
  • Anonymous Mar 29, 2014
    how to remove clip on back of washer so i can replace the damaged drain hose.
  • Anonymous Mar 30, 2014
    Drain hose has sprung a leak and I need to know how to change it.
  • 725 Answers
Hi Krazytech here, You will have to remove the cabinet to get to the pump end of the drain hose. First you must remove the top insert a putty knife to open the top lift up then remove screws that hold on the top then remove the screws that hold on the bottom. then you can get to the pump I alway replace the factory spring clamps with a screw hose clamp they are much better.. let me know
Posted on Aug 24, 2007
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
The grey drain hose split, anyone know how to replace this? Is it attached to the drain pump in the front? Also discovered that black drain tube is clogged at the front filter. This tube seems to be...
the drain hose is indeed attached to the pump area... sounds like you may be on well water if it is breaking the hose down that bad... if not that is unusual to have hoses break down like that... its not hard to replace the hose as they just have hose clamps on them ,but yes you do have to tear apart unit to get down to drain pump assembly... some of the units have a front kick plate you can remove to get to them and some you actually go into from the rear... i didn't look this model up but we work on all appliances and normally there is a way to access the drain pump.... some units front loaders you can actually tilt up and the bottom plate will remove to gain access to it also... just going to have to look around and make access the easiest way for you... once your in though it is a simple task to replace hose...
Jan 01, 2011 | LG WM1814CW Front Load Washer
Drain hose has a small hole spraying out water. How difficult is it to replace the drain hose myself?
sometimes u can repair that leak with electrical tape. is your machine leaking where the hose comes out of the unit? they only sell the drain hose with the wiring loom attached. better to repair than dismantel unit. please reply and i will help u whatever u decide, good luck.
Apr 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
It is leaking from the bottom during the wash cycle. What is going on?
If you mean its leaking anytime you have water in the drum,the first thing to check is the drain hose connection at the back of the washer,You'll want to do this with the washer pulled out,(don't let the drain hose drop below the water level or you'll have a mess)If its not leaking there you should be able to look under the washer & see which connection it is(usually the inlet to the pump) Might be as simple as tightening the hose clamps.Hope this helps
Jan 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from the bottom. Whirlepool Ultimate care
Most leaks on this model washer come form a worn or damaged drain pump, or drain hoses. You will need to remove the exterior case to access the washer interior to sufficiently inspect the washer components to be sure, however. The following link explains:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump IS the problem, there is a follow-on link included that explains how to replace it.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or require additional assistance, please post back and let me know. I hope this helps you.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you attach the drain hose to the wf448aaw
The Drain hose comes attached to the drain motor inside the washer and exits the back of the washer. It is gray in color. You need to place the drain hose into the main drain in the wall. It does not need to be attached. Usually there is a Black ruber section of hose that is in the shape of a "j". Just b sure that it is secure and doest pop back out.
Oct 07, 2009 | Samsung WF337AA Front Load Washer
Leaking from behind?
If the leak is coming from the back of the washer, the problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If the leak is coming from under the front of the washer, the problem may be the drain pump. These pumps can develop cracks and start leaking. they are non-serviceable and will require replacing is defective. The following link explains how: http://www.fixya.com/support/r397092-replacing_water_pump Inspect all internal hoses and hose connections as well. There are two drain hoses on the water pump, and several small hoses near the water inlet valve. These hoses can develop leaks over time. If the leak appears to be coming from the bottom of the wash tub, you may have a leaking tub seal, or cracked wash tub (worst case scenario). You will see tell-tale signs of water marks on the gearcase (transmission) if this were the case. On the lower right hand side of the wash tub is an air dome with a small rubber air hoses attached. Make sure this hose is still attached and has no leaks. The air hose can slip off the nipple it is attached to and water will begin to pour out of the washer when it starts to fill. This will be an "attention-getting" leak as water will gush everywhere. Double check the air hose just in case. If parts are required, you can purchase from any of the following websites:
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions about this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Drain hose leaks at junction in back of machine
If you find a solution let me know, I have a similar problem.
May 28, 2009 | GE Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Maytag MAV7600 Top Load Washer Logo
543 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
