Question about OKI 9800hdn Laser Printer
OKI 9800 with "342" error code
I have an OKI C9800. After replacing the waste toner cartridge and cleaning the toner transfer belt. I reinstalled the belt mechanism, and the toner drum units. Upon restarting the printer, I keep getting a "342" error code that says that the cyan toner unit has not been installed correctly. I have scrutinized every detail and cannot detect anything wrong with the installation of the toner unit. It is identical to the other toner units, and all the electrical contacts appear to be made when installed. I can't detect any mechanical reason for this. However, when restarting the machine each time, the message screen shows a question mark for the toner level. I installed a new toner cartridge, but the same question mark appears in the cyan toner level indicator. And after a few moments, the printer starts to do its prep cycle and then you can hear a very slight "clunk" and the the "342" code appears. Any clues as to what might be happening?
Problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Posted on Sep 16, 2007
Oki data c9500 belt always dirty
You will find the waste toner auger (Coiled wire in the plastic tube) is either snapped or blocked with hard toner. Its simple to remove as it just unscrews. If I remember correctly it sits under the transfer belt and runs down the back and right side of the base. Anyway clean and inspect it as that is what removes the waste toner.
Mar 20, 2018 | OKI Office Equipment & Supplies
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
Jul 08, 2017 | OKI Office Equipment & Supplies
OKI C9800 NON PAPER SENSE ERROR
remove the toner/drums and transfer belt. on the right side is the reg rollers. there is a black arm and sensor the detects the paper weight etc there. that will control the paper sense errors, make sure it moves freeley, clear of paper, dust etc.
Jul 30, 2014 | OKI C Office Equipment & Supplies
OKI C9800 CYAN TONER SENSOR ERROR
Exactly what is the error on the operator panel?
Jul 30, 2014 | Oki Electric Industry C9800 Printer
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Error 357
Hi - take the waste toner unit out and restart the printer. You'll now have a different error 'Check Waste Toner'. Open the front cover and put the waste toner back in. Let the printer go through the usual checks and hopefully all should be well.
In my experience this can be caused by not shutting the printer down fully before changing the waste toner.
JohnnySheffield
May 30, 2010 | OKI C9800hdn Led Printer
What is error 357 waste tuner box is full okidata c9800
The printer always puts out a little more of each color toner than is actually needed in printing. The excess gets dumped into the waste toner bottle.
The replacement part number for this printer is 42869401 and should last 30,000 pages. Order one from an OKI service center and it will come with the replacement directions.
I hope this helps.
Apr 18, 2010 | Office Equipment & Supplies
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI 9800hdn Laser Printer Logo
841 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
