SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
SOURCE: i have a intel D945GCCR mother board,and the usb
are they working at all or have theygot some kind of intermittent problem if its not the latter its most likely not wired correctly on the motherbord pins ,do you have the manual that came with the board if not type the boards name in google and download a pdf guide to your board and it will show you what pins go where
SOURCE: intel D945GCCR motherboard
You can download all the driver for your motherboard from th following link . You can download the driver for any operating system that you want to use.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCCR
SOURCE: USB Problem
hello mr.
this is not a software problem
this is hardware problem
if *********** board is in warranty
you can replace *********** board from the intel
if *********** board is out of warranty then purchase usb PCI sloat card and insert the
Testimonial: "Thank You Good Advice"
SOURCE: Intel D945GCCR SATA driver problem.
You shouldn't need the drivers till after the OS is installed.....just go into BIOS and check to see what placement it is in.....or boot up the windows XP CD and select it as the drive to reformat and install XP on. In Bios you can select which drive you want to boot. i.e. IDE/SATA it should have a model number of the one you have selected to boot just make sure it matches the modle number of the drive and you good.
