Question about HP Compaq Presario V2000 Notebook
Another "Won't Boot"
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom. Won't except any input. I tryed turning on with ESC pressed and it does the same thing as above, then goes to "Press to resume, to Setup" at the top then won't doo nothing.
  • skute61 Aug 24, 2007
    Thanks, I checked the keyboard cable, it's fine. I think when I got a different screen when I held down the ESC key, booting up, shows the keyboard is working. I dont think it has an external keyboard input
My guess is a faulty processor.  I had to replace my motherboard a while back.  Yesterday I was really proud because I got the machine up and running, proving, I thought, that I had successfully took it apart and put it back together.  It had been out of commission for a while, so when I shut it down, it asked if I wanted to do windows xp auto updates.
This morning I got the exact same issue you have, so I opened her back up and noticed that I forgot to plug the CPU fan back into it's socket.  So much for feeling awesome.
My guess is that while doing updates it overheated and died, but I didn't notice because I stopped paying attn to it because it was turning itself off.  I don't think it's a Windows thing because when I try to put a boot cd into the computer, it still won't read.
Dunno what to say...  I'll definitely post back here after I replace the cpu to see if I find an answer.
Posted on Oct 22, 2007
  • 661 Answers
First Press all the keys on the keyboard (computer on or off)a sweeping motion accross all keys will do, A stuck key can prevent windows from booting (seen as a keyboard error). it is also possible that your keyboard connector has come loose, check the keyboard connector (you will need to remove the facia above the keyboard and may have to undo a couple of screws to do this). could try to plug in an external keyboard, see if this allows you to bypass issue
Posted on Aug 24, 2007
SOURCE:
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
LAPTOP IS NOT BOOTING SCREEN REMAINS DEAD, ONLY I CAN HEAR IS A VERY MILD 2 BEEPS.
1>Take the battery out of the computer, unplug all external devices, and disconnect the ac adapter i.e there has to be no power source to the computer.
2>Press and hold the power button for 1 min and then put the battery in and connect the ac adapter
3>Start the computer and start tapping on f10 key till you get the BIOS screen, (grey screen with system informatiom, configuration ,... and etc on the top), press f9 and then press f10 to exit
4>If the issue is still not resolved ,start tapping on esc( may be del if not esc) as you restart the computer and select boot from hdd.
Jan 10, 2010 | HP Compaq Presario V2000 Notebook
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Prosario V2000 boot problem
This means that there is some component was not fixed well.
this error means: " press esc to change boot order"
"press F10 for setup press F12 to boot from lan"
with 2 beeps " that the system cannot find hard drive:
fixed every thing: and try this. if prompted to go setup , continue and find "load bios setup default and then save and exit.
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
264 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
