Question about Toshiba 32A43 32" TV
Menu keeps popping up
I have the same problem that was describe by other owner of the Toshiba 32a43 users. the menu keeps popping up. I have a 36a43 TV. I just have the remote senor repaired and then this happen. Does anyone have a code that can be used to disarm this problem? Or hoe does one fix this problem>
  • 3 Answers
This may be your fix,just clean all of those front botton switches with contact cleaner. It fixed mine!
Posted on May 24, 2009
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back
in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6
hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when
it starts to work,set new pin code.use your instruction book,to set all blocks
to N,,Clear all favorite channels + erase channels in tv 's memory if there in
there yet,takes a lot of time.it will keep resetting,remote won't work.let it
run awhile. then push exit, hold 5 to 10 seconds remote will eventually come
back,check your settings reset them, be sure menu is set to STOP, it may start
running threw all its modes again,let run couple hrs, then push exit 5 to 10
seconds to get your remote back.keep trying this. when you think the tv is
working right,turn it off for 10 seconds then back on. If it starts resetting,
let it run an hr,then push exit again to get your remote back,it has to reset
everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I
don't have w 1orking is the pic size button,Don't need that anyway. GOOD LUCK
Posted on Mar 20, 2009
    Novelist:
    Champion:
  • 232 Answers
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Posted on Dec 15, 2007
SOURCE:
Menu options pop up w/out me touching it. won't go away keeps popping up
Hello there id try Fully resetting the power to the unit if that doesn't seem to work check to make sure the menu key is not sticky if it is make sure the unit has no power and clean the menu key.
Jan 23, 2011 | Toshiba 32A43 32" TV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Tv problems
Have you tried taking the batteries out of the remote? Sometimes the buttons can stick.
Sep 12, 2008 | Televison & Video
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Menu pop ups
dopy, the problem is leaky tact switches on the control board, have changed out many of these especially on the 2003 model which of course is the 32A43, part number for the switches is 23344443, swap them and your done, BMW Rider
Sep 06, 2007 | Toshiba 32A43 32" TV
Demo wont go off
change out all the tact switches on the front control board and you`ll be good as new, common problem, BMW Rider
Aug 15, 2007 | Toshiba 32A43 32" TV
Tv problems
There are a number of things that can cause this.
If you have a compact flourescent lamp in the room, this can cause some models of TV sets to go nuts, or not respond to the remote. These compact flourescent lamps use a frequency band that is close to the data carrier freqency of the remote.
Excellent article about compact flourescent lamps interfering with appliance IR remotes:
http://www.neptunlight.com/files/IR-and-CFLs.pdf
The other thing that can be wrong is there may be a fault in the keypad assembly on the TV set, or a fault condition with the uPC.
Jerry G.
Jul 02, 2007 | Toshiba 32A43 32" TV
Hi, heres your fix, very common problem usually caused (but not always) by using windex to clean the screen, replace the front control boards tact switches, replace all of them, part number is 23344443, end of problem :) BMW Rider
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Toshiba 32A43 32" TV Logo
1,970 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
