Question about Hotpoint Aquarius WF210 Front Load Washer
Flashing FOO3 Hi every time I switch the machine on this flashing f003 appears, I have tryed holding the start/hold - on/off keys but it's still the same, i would be most greatful if anyone can help me out, I rang hot point they told me I need a tech to call out, I hope this won't be the case.
  • 641 Answers
The F003 error code relates to a deffective wash thermistor that should be replaced. Now its depends on your technical qualifications if you will do it by yourself or will call for a tech. Good luck!
Posted on Aug 24, 2007
SOURCE:
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Flashing key
Sounds like have inadvertently activated the child lock, select any program and press and hold the start button until the key light goes off approx 5-10secs. If this does not work please repost with model number as with some bosch models it is a different button you need to hold. (may be the time delay)
Mar 16, 2013 | Bosch Washing Machines
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
Dear sir .i have nokia e51 .when i start it .then (continue using phone in off line mode .)is seen ,and and all the keys are freez.plz give me the solution
There is software problem to restore your mobile first switch off your mobile
then press and hold 3keys in one time thous keys are
1) * key & number3 key hold both keys then
2) hold Switch on Button till your nokia blinks 3 time or hold it till 3mins
your mobile software will be restored.
it not solved then Please Renew you are mobile software if your a mobile technician then use your mobile flashing tools e.g JAF software flashing tool or UFS software flashing tool. thous are having bunch of cables select your mobile cable by name RM 244 it is the perfect cable for your mobile connect it to the software tool box it may JAF or UFS. then try to check then boot files if every thing is ok then click to flash it will start flashing your mobile. If your not a Mobile technician then please do not try the above thing it is harmful for your mobile it may get dead.
If your not a mobile technician then please visit your nearest Nokia Service Center (Nokia Care) they will do it in a proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 08, 2011 | Nokia E51 Smartphone
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Machine won't start. Keeps beeping and flashing picture of a key appears.
The child lock has been selected try holding in the lock button 10 secs to clear
Jan 03, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
130 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
