Question about Sega Genesis Console
Control pad does not work
Golf, shanghai,etc., come on screen but control pad does nothing
  • 20 Answers
The most common problem for Sega controllers not working is the controller itself. With the controller laying on a table with the buttons down take the back off with a small phillips screwdriver. Carefully lift the circuit board out trying not to disturb the buttons as they will fall right out. Turn the circuit board over and remove any of the soft rubbery pieces that may be stuck to it. You will see a set of contacts for each of the buttons. Clean these contact with a pencil eraser. Put it all back together and it should work like a charm for the next 20 years.
Posted on Dec 03, 2007
    Problem Solver:
  • 9 Answers
You should definately check the jacks for your console, that includes the controller's male and the console's female jack. If you have to, go ahead and wipe them clean with some alcohol, letting some drip in and let them air out. Its possible that some stuff has dripped inside the console's power or reset switch that caused problems with your Sega. You could try and go ahead taking the console apart, checking the terminals and stuff inside for mositure. Also, you shoudl try a new contol pad, as it definately didn't win any awards for its reliabitly.
Posted on Aug 25, 2007
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
V.w. golf convertible 98.M300RC remote.
it may have to be coded to the car by a dealership
Apr 18, 2014 | 1995 Volkswagen Golf
After the oven is on for about 5 seconds it has a buzzing or humming sound
This seems to be a failure of the control panel pad or switch as it does not take the command.
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Jan 11, 2013 | Amana MVH230 Microwave Oven
Why wont my 1994 vw golf 1.8 start without a jump or bump start not sure if its the battery as all lights\ sunroof etc work
The first thing you need done is to have the battery load tested and verified as being in good condition,.
Oct 04, 2012 | 1996 Volkswagen Golf
Control pad not working. Some lights are lit but
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Get me the make and model number so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Sega Genesis Console Logo
119 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Norman Worley
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
