The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Check to see if both the upper and lower blades are turning. If the motor is running and the blades are not turning, then it is probably just a broken gear.
I have a Destroyit 4002 cross cut paper shredder. I have ordered parts twice from shredderparts.com
Both times they were friendly and sent me the correct parts.
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
Yes. There are two electromagnetic sensors (front and back). If defective, the main board will show a yellow or red light. These sensors function with the cabinet which is magnetized in the center (front and back).
I call 1-800-223-2508 and ask for the phone number of my local dealer on Destroyit paper shredder & call them and my gear in the mail coming.
