Question about Kenmore 75050 Wall/Window Air Conditioner
Leaking water my kenmore 75050 ac is only a month old and is leaking water fm the rear all about midway up is this normal? It's also making an odd sound. Is there a place i'm meant to empty water from a tray or something? I can't find one if so.
    Problem Solver:
  • 18 Answers
The odd sound might be the fan hitting the water, its supposed to do that. The water gets thrown onto the condenser coils to help evaporate the excess water.
Posted on Jul 01, 2008
  • 725 Answers
You AC should drip water from the rear this is normal it should be tilted to the rear. I don't know about the odd sound..what does it sound like? let me know
Posted on Aug 24, 2007
I have a 2010 range rover sport, my light comes on for about 5 days then goes off for a week. this has been going on for 4 months???? The codes are P2097 and P219A 2 test and no one knows?
  • Other oxygen sensor related DTCs
  • Air leak in the exhaust system between post catalyst oxygen sensor-odd and catalyst
  • Air leak in the exhaust system between catalyst and exhaust manifold flange
  • Air leak in the exhaust system between pre catalyst oxygen sensor-odd and post catalyst oxygen sensor-odd
  • Air leak around pre catalyst oxygen sensor-odd
  • Air leaks within the intake system
  • Air leak around fuel injector(s) bank 1
  • Air leak around spark plug(s) bank 1
  • Low fuel pressure, fuel injector(s) leak, fuel system leak bank 1
  • Camshaft position actuator sticking
  • Airpath blockage between throttle butterfly and inlet poppet valve
  • Post catalyst oxygen sensor-odd failure
  • Cylinder head gasket failure
Aug 20, 2015 | Sony ICF-2010 AM/FM/SW Radio
2003 Ford expedition AC question they want to replace the condensor, compressor, evaporator coil and condensor coil. how reasonable does that sound?
you have a leak and if you can hear it or smell it its a good one, most likely its a connecting leak where ever the components connect to each other. with an internal seal leak, such as compressor or evaporator, your freon will last about a month,with a external connection leak, your freon last a couple days
May 24, 2013 | Cars & Trucks
I can't find one this model replaced model 74054 purchased in 6/10/93 thank you
Your message was a little confusing. But, if you're looking for the Kenmore 75050 Thru-Wall/Window AC, you can find it at Sears online at the following link.
Hope this helped you find the model you wanted. Please let me know. Thanks.
Jun 09, 2011 | Kenmore 75050 Wall/Window Air Conditioner
I just bought a samsung 15k BTU window a/c, I haven't seen any water dripping out of the bottom of the unit. In fact there is absolutely no moisture anywhere. Is this normal. Humidity is low, and it is...
If the humidity is low then the amount of water removed will be low. The AC (I assume is a window unit) May be evaporating it off as soon as its drained outside..
Yes in low temps and humidity it is normal for no moisture to be made in abundance.
This is all assuming the temp is coming down as you direct it to.
Please rate me as high as you can and thank you for using fix ya.
Apr 28, 2009 | Kenmore 75050 Wall/Window Air Conditioner
No water
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Sep 18, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore aircondition
First is to make sure the evap and condenser coils are very clean. A dirty evap coil will cause icing as well as a blower not running and low freon. Hope this helps. Thx RepairUSA
Aug 31, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Kenmore 75050 Wall/Window Air Conditioner Logo
321 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
