Question about Zyxel P-334WT (P334WT) Firewall
Not working with Vista
The router is not working with Vista computers. No problem at all with XP. I have tried Microsofts solution adding the registry key DhcpConnDisableBcastFlagToggle in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{GUID} But this dos not work. The router and the computer is configured to DHCP. When giving the computer an IP and changing the netcard to 10 Mb half duplex it succeded for a period. But next time the computer is turned on I must configurate it again. I would like to use DHCP and 100 Mb full duplex. Any suggestions?
  • StormyBoy Aug 25, 2007
    I have today sent a mail to ZyXEL support describing the problem. When I get an answer I will post it in this group.
  • 196 Answers
There is a list of Vista supported routers here: http://www.zyxel.com/web/support_vista.php Your model is not on the list, so I would begin by emailing tech support.: http://www.zyxel.com/web/support_feedback.php
Posted on Aug 25, 2007
    Problem Solver:
  • 9 Answers
May the router is not compatible with vista. Just try to use it with xp.
6ya staff
SOURCE:
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
We have two computers and we are trying to set up a network so both computers can use internet, the host computer has windows vista and coble modem the other computer has windows xp and is about 275'...
Hi.
You are going to need two things for this to work.
First, you need a wireless router, these usually run about $50-$60.
Then after you get the router, you need a wireless usb adapter, so that the xp computer can receive the signal from the router.
Connect the lan cable from the cable modem that is currently attached to the vista computer to the router, then connect a lan cable from the router to the vista computer.
The xp computer is easier.
After you have the router hooked up, just plug the usb adapter into the xp computer, install any software that comes with it, and after it install the drivers it will be able to connect to your router, and have wireless internet.
Make sure that you know the name of your router, that way you are connecting to the right one.
I hope this helps you out, and have a good day.
May 21, 2011 | Microsoft Windows XP Professional for PC
My 120 gb zune has stoped syncing with the libary for some reason i've added all the updates and now its stoped working
usually the zune program dosnt work with a vista system and the 4.0 upgrade. your best option is to try to find a downgrade for zune 4.0 or and alternitive system to use while microsofts come out with a patch for the vista.
Jan 11, 2010 | Microsoft Zune JS8-00001 Digital Media...
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
I have a wireless keyboard and mouse (Microsoft) I also have Vista operating system. When the computer sleeps when not being used, once awakened, the keyboard doesn't work and computer needs to be...
chances are its a driver problem, windows vista is not very stable, even with the 2 service packs now available. if u can, go to microsofts website and try to find drivers for your model of mouse and keyobard and get the latest drivers. otherwise, disable the sleep function or format the computer with windows 7 when its released, or windows xp.
Jul 08, 2009 | Microsoft Multimedia Keyboard/Wireless...
Cant get my vista labtop to print through router
Did you share the printer PSC 1410 in the XP Desktop computer??
Thanks
Riz
Jan 14, 2009 | HP PSC 1410v All-in-One Printer
Problems adding a vista computer to a mn-700 network
you need to install a driver in your vista which will enable you to print your files.i hope this helps
Dec 29, 2008 | Microsoft MN-700 Wireless Router
Vista and remote printing
Have you applied SP1 to Vista? It is supposed to fix a plethora of issues.
Oct 24, 2008 | NetGear DG834G Router
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
Open Questions:
See all Zyxel P-334WT (P334WT) Firewall Questions
Zyxel P-334WT (P334WT) Firewall Logo
205 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
