Question about Kenmore 43042 Front Load Washer
Kenmore front loader model 417.29042992
Hi (and thanks), Just cleaned the boot out and it was full of "stuff." Now, I still have a large thumping noise on the spin (once it reaches speed.) It gets going like a rock star! The basket spins freely by hand except for a squeek/creak at one point in the rotation. The machine is probably 7 years old. This has 2 springs above and 2 pistons below.
  • rafur Oct 10, 2007
    It seems as if the stainless steel drum is very loose. You can make it move in a variety of angles (not just round and round.) This also seems to explain the type of thumping I'm hearing as well.
I had the same problem, needed to replace the entire inner tub
Posted on Oct 24, 2007
  • 625 Answers
Check and make sure the washer is LEVEL otherwise when in spin, it may "walk" across the floor. also if it's not level then the tub will "tilt" in one direction and may contribute to the thump, thump.
Posted on Aug 24, 2007
SOURCE:
What is the thumping sound in my frigidaire front loader dryer?
Hi Denise, thank you for your question. There could be a few possibilities of why your Frigidaire dryer is making a thumping noise. To better assist you; may I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you - Z.
Apr 26, 2014 | Frigidaire Refrigerators
I was given a kenmore quei pack 2 washing machine.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Thumping when spinning
There are two shock absorbers on that model. They are located on bottom on both sides of the drum and can be replaced easily for about $35.00 in parts. That will fix your problem. The original shocks were poorly designed, replacements are better.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Leaking front loader
the most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Dec 03, 2008 | Kenmore 44102 Front Load Washer
Kenmore HE2
Yes, it will. There are two screws holding the bottom panel in place that you will need to remove first. Your pump may be constructed differently than the full size HE models. If you do not have a clean out trap, unplug the washer and remove the pump. Flush it with water to clean out the impeller. DO NOT submerge the motor portion in water, however. If you have to remove the pump, just disconnect the electrical connections and the inlet and drain hoses. DO NOT remove the hose from the bottom of the wash tub. Disconnect all hoses from the pump only. In my past experience, this particular hose is a real bear to get back on. You may not have to do all this. I include these instructions, however, because some of the small front loaders do not have a clean out trap on the drain pump. I hope this helps you. Let me know if you have further questions.
Sep 03, 2008 | Washing Machines
Kenmore 43042 Front Load Washer Logo
344 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
