Question about Audiovox P88 CD Player
Power connected right, pops fuses in player
I changed fuses as suggested in this forum and when I reconnect power the player pops the new fuse. Bothy constant and ignition switch power are hooked up right. Sounds internal and is it worth fixing?
  • 709 Answers
HI Paul,
No one evidently wants to tell you that your Radio is shot. The circuits in the head units is not worth repairing. It is too minute and hard to do to the point it isnt worthy of attempt. I do not mean to be the harbinger of doom here. Just get a new head unit and this time dont get an Audiovox.
Posted on Nov 25, 2007
SOURCE:
I have a 1999 Subaru Forester. The battery went dead after many ,many years. I replaced the battery. Upon connecting the new battery, the car alarm went off. I disconnected the battery from its negative...
Most all aftermarket radios have their own fuse next to the wiring harness plug. Depending on the brand, it may only take a few minutes to pull the radio out of it's sleeve to check for the fuse. Usually, you can pop off the trim ring to see what you are working with.
Jan 26, 2014 | Subaru Forester Cars & Trucks
I have a 2006 ford explorer, with dual and elect contols, the a/c went out meaning no clutch, checked freon level its ok, checked clutch gap, checked and put all new relays and checked the diode and all...
You may check your fuses and relays you have a AC clutch relay in the battery box that has two fuses feeding it they are also in the fuse box under hood fuses 48 and 24 bothy 10amp fuses. fuse 24 is hot all the time and fuse 48 is only hot when car is running
May 23, 2011 | 2005 Ford Freestyle
I turned the DVD player off last night and this morning it will not turn on. Any thoughts, suggestions? I do have a DVD in the player that I need to get out somehow....
it is possible that the power supply unit in the DVD has failed. You will need to open and ccheck, the fuse might be open and if a new fuse blows out then the SMPS unit is faulty.
Possible that the Sm driver IC /driver has failed. Possible also for allied components to have failed.
Or else you can change with a new unit.
Helpful?
Aug 28, 2010 | Samsung DVD-V3500 DVD Player/VCR
Had bad battteries installed new now abs light on air bag light on power windowslocks and trailer plug don't work all fuses good no power to fuse terminals
try unplugging the battery and wait about ten minutes...to let the computer reset..then reconnect the battery..if that doesnt work..try popping the battery with jumper cables from another car...(while connect)
Jun 29, 2010 | 1999 Dodge Ram
We lost the cigarette ac adapter and purchased a new generic one, plugged it in and heard a popping noise. Now we can't get the dvd player powered up again. any suggestions
The end of the plug which gets inserted into the cigarette lighter/power port should unscrew. Inside is a fuse. You need to replace it with the identical size and rating of fuse. Check the unit with an ohm meter for any shorts between both conductors. If the unit is shorted toss it and get a new one. If it isn't shorted it should work with a new fuse. Let me know if you need any more help.
hardrocko
Feb 02, 2010 | Polaroid 7" Two-Screen Portable DVD Player
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Audio Players & Recorders
Keep popping fuse on 1990 corsica...
You know whats connected to the fuse, now start systematically disconnect each component and each time you try the fuse same fault, reconnect, till you ge t to the component which you disconnect and do not blow the fuse, now you know it is in that component start tracing the wires/bulb connections. , have 10 spare fuses ready'
Aug 16, 2009 | 1990 Chevrolet Corsica
My car fuse recently blew (which controls live feed to my player). However when I changed the fuse the player now wont light up. I know I have power because I can eject a CD and the reset button causes the...
Check your Ground wire on the Wiring Harness for the Stereo. If good Disconnect the Power and Ground for 5 Minutes then Reconnect. See what we have got then. Let me Know!
Jan 04, 2009 | Sony CDX-CA750X CD Player
Connecting my cd stereo to 1990 Ford Taurus
since it worked before and you didnt change anything and now there is no power it looks like you blew a fuse when connecting wires. check the radio fuse on the door panel, and check the int. lighting fuse under the hood of the car. take both out and see if they are blown, if blown buy new fuses and replace.
heres the wiring diagram for a 1990 Ford Taurus:
Left Front (+) orange/lt green
Left Front (-) lt blue/white or Blk
Left Rear (+) pink/lt green
Left Rear (-) dk blue/ orange or Blk/Wht
Right Front (+) Wht/Lt green
Right Front (-) Dk green/ orange
Right Rear (+) pink/Lt blue
Right Rear (-) Tan/White
Lt green/yellow Hot at all times
Black - Ground
Yellow/Blk - Ignition
Lt blue/red - Acc
Orange/blk - Dimmer Lights
RED - Lights
Aug 22, 2008 | Car Audio & Video
Audiovox P88 CD Player Logo
41 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
