Toshiba 36HF73 36" TV Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba 36HF73 tv with remote (CT-90047). Remote doesn't work.
We have changed batteries, re-coded etc, remote works sporadically. The remote will turn on other components, could there be a problem with the remote receiver in the TV? Can it be fixed?
BOB BROWER
Level 3:
President:
  • Master 267 Answers
  • Posted on Mar 26, 2009
BOB  BROWER
Master
Level 3:
President:
Answers
267
Questions
0
Helped
158771
Points
1169
You just may have a bad remote . remotes go bad in strange ways sometimes messing up a program for just the tv and all other things iits programed for are fine . the recever in the tv is rock solid i have NEVER had one go bad on a modern tv (tv made in the last 20 years) try a new remote and enjoy............. Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Codes for toshiba remote CT 90232
It isn't the codes for the remote that matter, it is the television that you want to operate.
HOWEVER, this particular remote is custom made for one Toshiba device only!
Toshiba CT-90232 Factory Original Remote Control for TV's
Amazon https://www.amazon.com > Toshiba-CT-90232-Factor...
Toshiba CT-90232 Factory Original Remote Control for TV's ; Compatible Devices. Television ; Connectivity Technology. Infrared ; Controller Type. Button Control.
Rating: 4.9 · ‎7 reviews · ‎US$14.99
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Press menu on remote, then setup, select cable/ant, then select whichever service you have. before leaving menu select AUTO TUNING.
That should find the channels available on whichever service you have.
if that doesn't work try this link, you'll probably have to copy and paste it.
https://www.manualslib.com/products/Toshiba-Ct-90326-5897677.html
Does not command the tv
Remote controls often fail. If changing batteries does not work buy a 'universal' remote from any tv store.
You will need a set up code to link it to your tv. Get the code here http://www.tvcodes.com/
2helpful
2answers
Removing parent block on a used Toshiba 36HF73 36
If you don't have the unlock code you can do this to remove it. Please take a few moments to rate my answer..Thank you...
If you cannot remember your PIN code
While the PIN code entering screen is displayed, press RECALL
four times within five seconds. The PIN code will be released
(Blocking Reset status restored)
1helpful
I can't program my Toshiba TV to the CT 91507 remote
change battrries and select our old remote control codes
2answers
30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
