Question about Motorola Mobility RAZR V3
Motorola Razr When I insert my sim chip into my new razr it reads the chip and says my phone number when first being turned on, but it fails to log onto the network and reads "No Service" in the signal strength area.
    Brigadier General:
  • 7,752 Answers
You need to have the internal antenna checked....or go into the network settings and change the band from auto to manual and have it do a manual search.
Posted on Feb 24, 2008
Why Is Status 254 showing on failed text to regular recipient - plenty of phone credit , 29 msgs in out box , have had more than that Phone is Motorola Razr Thank you
i think you have a network problem.
you can turn off your phone and turn it on again after 5 minutes then try texting again. if the problem still exists, turn off your phone again and remove the battery and sim card. insert your sim card into another celphone and try to text there. if you have successfully sent the message, you can insert back the sim into your razr phone.
see if this helps.
May 19, 2011 | Motorola Mobility RAZR V3
Got a motorola razr v3 on ebay. Not reading SIM card.
It may be caused that when you take out sim from old phome it has damaged, try for old one is it still working? if not then your sim is dead, also old phones made SIM-s to be bend and such SIM-s have difficlt electrical connection with new phones.
Also find if "this sim only" is activated in your phone.
It must give you signal, Insert sim card, or insert proper sim. If insert sim card warning card is damaged or have not enough good connection, if another, then this sim only is activated you first you must unlock it to work .
Aug 20, 2009 | Motorola Mobility RAZR V3
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
Jul 09, 2009 | Motorola Mobility RAZR V3
Razr v3r
Hi folks - I took apart and totally destroyed my Verizon branded RAZR V3m. There is NO SIM card. Instead, there is a memory chip hard wired to the circuit board. From what I saw, this memory chip is preprogrammed with the phone number and carrier features. The card picture referred to above is for the micro SD card. This card is just for additional memory - for pics, video, and music, dependent on the carrier. I also went to the Motorola web site. They're unlocked RAZR V3's have a SIM slot underneath the battery. Bottom Line? If your RAZR V3 doesn't have a SIM card slot under the battery, forget it. You can not change carriers.
May 17, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Problem with Motorola V3 Razr
Go to your settings, choose Initial Setup, choose Language and hope English is one of the options you can choose. My Razr is old so hopefully the options are still the same.
Aug 09, 2008 | Motorola Mobility RAZR V3
Can't find the sim card! Help!
sim is the card you were given to work your phone and make calls.
Well it sounds like you need to put your simcard in the phone and it will be working.
If you need assistance you should have a customer rep in store help you.
Jun 23, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr says insert SIM card when it's already in there
You May Have Fryd Ur Sim Card Did U Try Puttin It In Any Other Phones Besides The Other Model?
Jun 14, 2008 | Motorola Mobility RAZR V3
Motorola razr turns off.
your main-board could be failing but you should have it reflash the firmware on the phone that might solve your problem if not then replaced the phone.
Jun 07, 2008 | Motorola Mobility RAZR V3
Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Jan 02, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
