Question about RCA F32649 32" TV
I HAVE AN OLDER VERSION RCA 36 INCH TV
WHEN I TURN THE TV ON IT STARTS SPARKING. WHEN IT SPARKS IT FLASHED THE PICTURE ON AND OFF AND IT SOMETIMES SPARKS AND TURNS OFF THEN BACK ON. MY BOYFRIEND TRIED TO LOOK IN THE BACK AND GOT A BIG SHOCK. WHAT DO I NEED TO REPLACE IN ORDER TO GET THIS FIXED
  • Anonymous Sep 12, 2008
    flyback transformer arcing
    New Friend:
  • 76 Answers
Your problem is flyback transformer cap is leak or tared due to ageing or rust. Since it is high voltage transformer your boyfried get shock. If you have technical knowledge or technical support just try the following process. Switchoff the tv and remove power chord from plug. Wait minimum 4hrs. Then remove the back cover clean picture tube and transformer cap with IP solution. After allowing 30mins dry switch on the tv. All the process will be done by service engineer only. Risk of electric shock.
Posted on Aug 24, 2007
Buy another one fool
Posted on May 05, 2008
SOURCE:
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
TV keeps flicking off and on. Picture will go away and fade back
Seems like a bad contact somewhere - could be bad / deteriorated solder connections somewhere on the circuit board, broken wires or similar - check any connectors (especially in the area where you noticed sparking), see if the pins have bad solder contacts, also check other components - resolder any bad connections, this might solve the problem.
regards
3rq8 (Triarcuate)
Sep 10, 2009 | Televison & Video
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
Set video on older 36" rca colour tv Model # f3667et
take hammer and give it the good ole smasharoni as hard as u can
Jun 13, 2008 | RCA F36673ET 36" TV
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
RCA F32649 32" TV Logo
118 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
