Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Picture Channels 2 to 7 plus 15 and 21 are snowy but no sound. All the other channels are fine. I plugged the cable line directly into the TV and same problem. Plug the same cable line into another TV and I get all the channels. I have tried everything in the menu. Any idea? Thanks
    Genius:
  • 1,139 Answers
Ther is a test you could do is you had the proper equipment, and that would be to inject a know good RF signal into the tunner F connector and chech tha point where the RF/IF is converted to audio and video, to determine if the proble is a bad tuner or not. The equipment is a VA62A Universal Video Analyzer. Its a great piece of equipment for this type of work. another thing you can do is get an RF Modulator from Radio shack and input a video and audio signal in to it and set it to channel 3 and connect the F connector to the TVs F connector. The set the TV to channel 3 you should see the picture and hear sound in channel 3. The VA62A is best because you can set it to emulate all of your channels from 1-87 standard TV and Cable TV. In any event a test needs to be run to see if the tunner is at fault.
Posted on Sep 08, 2007
No sound on analog channels
Grab your sharp remote and press MENU, arrow over to SETUP, arrow down to RESET and press enter and follow that prompt to reset the unit. Once that is complete turn the tv off and unplug ONLY the tv for one minute then plug it back in. Then turn the tv on and see if you have channels, if you do, your audio should work on you analog stations, if you have no channels and all you see is a snowy picture do the following press MENU, arrow over to SETUP...arrow down to CH SETUP and press ENTER...you will then be at a screen that says AIR/CABLE, press ENTER, select CABLE or CABLE(STD) if that option is available to you. after then, arrow down to CH SEARCH, press ENTER, then you should be highlighted on ANALOG AND DIGITAL SEARCH...press ENTER and wait for 15-30 minutes ( or until you get a picture back) and make sure you DO NOT press any buttons or turn the tv off and you should be good. good luck 2 u
Feb 10, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Snowy picture
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
Sep 08, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Power went out while tv & Direct TV was on
The garbage on your unused channels are not important, just artifacts from signals not strong enough to produce a picture.
The 'blue screen' on #3 is what many sets use when they sense they are connected (terminated) to 'something' but not receiving any signal.
If sounds a lot like DTV's receiver took a hit.
If you have a second set you can borrow or drag to the receiver, try it first but I don't think it is your problem unless the cable input on it was zapped.
Jul 12, 2008 | Televison & Video
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
