Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vertical spin I have a 32w3 and when it warms up it will go into a vertical spin for apprx 5-10 minutes and then quit, it has been getting more as time goes on, Help Please.
  • 11,361 Answers
More likely to be bad LCD controller, see sample here: notes: I removed the cover from the board. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: there are more than one version of the board, http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
Be careful when remove the back cover! the switch assembly is attached to the back panel, do not yank too kard to remove the back.
Posted on Jan 04, 2010
SOURCE:
Vertical deflection! TV warms up about 20 minutes and vertical problem clears.
Chances are you have bad solder joints on the main board, take the back off the set and flip the board over. Next check the area around the high voltage transformer, if you are handy with a solder iron, re-solder all the pins around the flybach transformer, then you should see a vertical ic chip mounted to a heat sink next to the flybach, re-solder all pins and any other you might see.
Dec 28, 2010 | Samsung TXG2547 25" TV
I HAVE NO PICTURE , ONLY SOUND?
This sounds like a classic problem. Chances are real good that you have a vertical IC that needs resoldered. It is mounted on an heatsink and may have 7 pins. You will need to pull this IC out and clean the board with a flux cleaner and reinstall this IC. Also, replace any capacitors in the immediate area of this vertical IC. A bad capacitor will run this IC quite warm and will produce bad grounds. If you inspect closely, you will see solder rings [cracked] around each pin of this Vertical IC. This would be the first step for repair. Thanks for asking and show a few hands of support!
Oct 07, 2010 | Sony KV-35S40 TV
Start up problem
Bill;
Cause 1
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB.
2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Replace all these if they look bad or not. If you can't do it yourself call a service Company and get an estimate, it should cost about $450 if they know what they are doing.
Thanks using FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi VS-50705 50" Rear Projection...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
White vertical lines in Zenith lcd projection tv
Get price of a LCD drive board first, then call a shop to see how much they would charge to replace it. If you have already researched the price you can get a better deal. But I really wouldn't try to replace this yourself. It takes major disassembly and alot of training just to get this model taken apart and put back together. Good luck, Russmann.
Jun 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
No Raster, but sound works
sounds like vertical deflection has caused the tubes to go into blanking. Do you still have on screen displays? Try resoldering the vertical output IC. If that doesnt help the vertical output may be defective.
Apr 04, 2008 | Samsung HCL473W 47" Rear Projection...
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
81 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
