Question about Abit BL7-RAID Motherboard
Asus A7V8X 1 gb sim
Hi i have a 2gb amd processor and a Asus A7V8X motherboard see motherboard info Motherboard Properties Motherboard ID 06/10/2004-VT8377/VT8235-A7V8X-X Motherboard Name Asus A7V8X Front Side Bus Properties Bus Type DEC Alpha EV6 Bus Width 64-bit Real Clock 166 MHz (DDR) Effective Clock 331 MHz Bandwidth 2650 MB/s Memory Bus Properties Bus Type DDR SDRAM Bus Width 64-bit Real Clock 166 MHz (DDR) Effective Clock 331 MHz Bandwidth 2650 MB/s Chipset Bus Properties Bus Type VIA V-Link Bus Width 8-bit Real Clock 66 MHz (ODR) Effective Clock 530 MHz Bandwidth 530 MB/s Motherboard Physical Info CPU Sockets/Slots 1 Expansion Slots 6 PCI, 1 AGP RAM Slots 3 DIMM Form Factor ATX Motherboard Size 240 mm x 300 mm Motherboard Chipset KT400 Extra Features Q-Fan, CPU Overheating Protection, JumperFree, Stepless Freq Selection and i recently bought a 1gb of ram the same PC2700 333mhz specs of the two 512mbs i currently have and when i put it into my comptuter windows doesnt pick it up. and whn i put it in on its own i get a bios beep every 2ish seconds which i belive means that it is a memory error. Does this mean that the ram is damanged or that my motherboard cannot accept a 1gb sim?? please help
  • 78 Answers
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Posted on Aug 23, 2007
SOURCE:
Is it possible that AMD Athlon II X2 (3.0ghz) processor will fit in in this ASUS A7V8X-X motherboard?
hello there,
  • Socket A CPU support Type,
  • models Athlon, Duron, Athlon XP
  • The AMD Athlon II X2 is a Socket AM3, sorry to tell you that this motherboard and CPU will not work together correctly. New motherboards are always fun
Jan 27, 2011 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Can I upgrade my PC with existing A7V8X-MX motherboard with higher processor, Presently I have AMD Atholon XP 2000+
It also supports Socket A for AMD Athlon™XP up to 3200+ processor
Thoroughbred/Barton core support
Nov 17, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
Network driver
Follow these steps to get the right network driver for your asus a7v8x-x motherboard.
1. Click the link: http://support.asus.com/download/download.aspx
2. On Select Product, scroll down and choose "motherboard.
3. On Select Series, scroll down and choose "Socket A(462)"
4. On Select Model, scroll down and choose "A7V8X-X"
5. Click Search button
6. Select Operating System and click Search
7. Click "LAN" and select one from different download sites.
Good Luck!
Please do rate this answer and give me high ratings.
Thank you for using Fixya.
Sep 07, 2010 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
My Asus A7V8X-X AMD Athlon 2500 motherboard was custom built. There are three fans, front,CPU, rear. There are only two motherboard connections, 1 chassis, 1 CPU. rear is disconnected. How can I connect...
If your rear fan has a small 3 pin connector and there are no connections of that type on your motherboard, you will need an adapter to connect it to a four pin molex connector from your power supply. Something like this...
http://order.store.yahoo.net/cgi-bin/wg-order?yhst-39083765508394+4to3
Aug 05, 2010 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
I have asus motherboard with amd processor , i tried to attach multipal harddisks with it but it does not work , what i have to do? for proper functioning?
you need to make one hard disk master and other as slave ...for this you have to change jumper setting which you can find near to the IDE cable ..
Jun 28, 2009 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
DRIVERS
Hi, click on this link to load all the drivers for the Asus A7V8X-MX SE motherboard.
http://support.asus.com/download/download.aspx?modelname=A7V8X-MX%20SE&SLanguage=en-us
You might want to add this to you're favorites.
Enjoy!
Mike
Jul 12, 2008 | ASUS A7V8X-MX SE Motherboard
Abit BL7-RAID Motherboard Logo
271 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
