Question about RCA F36668 36" TV
RCA F36674ET - Only beeps when turned on
My screen started showing horiz. lines across top and botom of screen for a few seconds while making bbzzzz sound off and onn for about 2 days, then I went to turn on and nothing except a beeping sound from within the TV itself. Cahsis is a CTC1697CA. Built in /sept 1997
    New Friend:
  • 76 Answers
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Posted on Aug 24, 2007
SOURCE:
Blue screen rca tv model 14f512t
you will have to take it in to get repaired. might of put a speaker or something megnatic near your tv.
Oct 21, 2012 | RCA 14F512T 14" TV
I have a Mitsubishi VS-5077 the screen has gone black, it started out with the darker colors going green, I was having to boost the britenees, than a line would flash vert. across the screen, now no...
You definitely have bad solder grounds. I have repaired a few of these. You will need a TV tech pull the boards out and resolder them. The worst board would be the one on the left [signal board, has rca jacks. rf connector]. And they may as well solder the second board. You will have a restored TV when completed. Thanks for asking and show a few hands of support!
Oct 10, 2010 | Mitsubishi VS-5077/78 TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
NO PICTUR JUST A BEEP SOUND
Shorted Horizontal output transistor caused by bad horiz
transformer....parts to replace = Asti 2078 ( 257805 ) xformer
and 237470 RCA xistor..............................T.
Mar 03, 2008 | RCA F36450 36" TV
RCA F36668 36" TV Logo
247 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
