I bought a 32cc mcculloch blower runs idels great but when i reve it up it shuts off
SOURCE: Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
SOURCE: 32cc mcculloch back blower i service it chabge fuel and spark plu
you need to drain all the fuel and start with fresh and install a new spark plug
an she will run
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
SOURCE: McCulloch 32cc backpack leaf-blower
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
