FixYa.com
Tags:
Casio QT-8000 Network Terminal
Memory Upgrade
posted by hfermin on Aug 23, 2007
I have about 90 QT terminals, installed at a Supermarket Chain. I tried to upgrade the machines to 512RAM using regular DDS SDRAM.
The problem is once the machines restart, it hangs in the BIOS. after rebooting several times, it will come up.
Is there a specific brand of RAM to be used with this terminal?
Thanks
Henry
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 26, 2007
FixYa! (100)
Zt3000
Rank:Guru Guru
Rating: 86%, 281 votes
First, this is what I would do before buying more RAM.
Turn off two terminals, take the memory from one to add to the other (no new chips please). I'll assume each machine has 128MB right now and I'll assume there are only two memory slots.
If it boots up fine with 256MB, then I'd try to match the RAM exactly.
Probably using PC1600 with/without a SPD module chip.
Use CPU-Z to find out the memory details.
http://www.cpuid.com/cpuz.php
ZT3000
Beta tester of "0"s and "1"s
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Network Terminals problems?
Network Terminals
Windows XP
Hi - I keep getting an error... Answer This...
Network Terminals
Networking Printer
How would I network 5 computers... Answer This...
Network Terminals
program
serial port Answer This...
Network Terminals
I need help
i am trying to install a 3-port... Answer This...
Network Terminals
Printer Copy Mode
I have a HP Photosmart C7280. I... Answer This...
Repair Service
Find Network Terminal Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
