Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
Dtv Hi I have a Samsung HD digital TV ( LE26R73BDX )about a year old. Recently the DTV has stopped functioning. It only allows the use of channel 5. None of the controls work when I want to use DTV, not even D.MENU. So I can not reset the system at all. Somebody advised me to turn the TV on by pressing the buttons ?INFO, MENU, MUTE and POWER? in sequence and within 1.5 seconds in order to open the MENU screen, but it didn?t work. On the other hand the ordinary TV works perfect. Is there anything that I can do to resolve this problem? Yours Allen
I followed your suggestion and it works! You certainly do push the
info
menu
mute
power buttons but I cannot remember the exact order.
I may have pressed them altogether, or in a quick sequence and it may have been in standby mode or switched on.
Fiddle with it, because it does work.
What will happen is that you will get a set of commands on the screen. Use the remote to get to RESET. At first I coudn't get this to work as I kept pressing the "enter" button in an attempt to select this option, but actually you just need to press the right arrow button to select it.
Reset comes into place. Wait a while and press a channel number, then just re-tune. You will have to re-tune anologue and digital. This works - please share with others. Eamonn
Posted on Jan 29, 2008
This worked for me as described in the original post.
Thank You ever so much, it saved me a lot of hassle trying to organise someone to come out and fix it.
Posted on Mar 01, 2008
The above solution works brilliantly, but be warned, SAMSUNG do not recommend untrained people access this set up menu. Incautious use can screw up system totally. They claim.
Posted on Feb 10, 2008
2 Suggested Answers
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
Could you please advise if our model Samsung TV. LE26R8 purchased in 2007 has the built in FREEVIEW tuner. Many thanks, Peter smart
Yes it does.
If you look on your remote there should be a dtv/atv button and a dtv menu button to tune it into dtv.
Oct 16, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE32R74BDX ...DTV problems
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Oct 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Need help
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
357 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
