Hello, I have a sears kenmore model 110 20902990 washer that doesn't spin but does drain. The motor is turning but drum doesn't engage. It did smell as if something was hot or burning. Also there was some black dust (rubber) under the machine. thank you!
I replaced the motor coupling on my washing machine and it now agitates and spins. The new problem is that it does not have the power it used to. It spins slowly and does not agitate like it used to.The first thing you should check would be that you had pressed the motor coupling far enough onto the motor shaft and the the shaft on the gear case the shafts should be flush with the coupling if not this will cause a bind on the motor and also cause it to have a hard time starting
I have the same problem where I replaced the motor coupler and have agitation and spin, but smell something scanky and burning. I checked and I did not seat the coupler completely, but fixing that did not get rid of the smell. I am wondering if something is dragging. The motor feels hot to the touch after just one agitation cycle and one spin cycle.
