Question about kawasaki 1152 System
Cant See I connet every thing right and i can see the dvd that is playing. But can hear it. Every thing else works but the video does not .
  • 661 Answers
Do you have your tv set to the correct AV channel   (for a scart connection) look at the Scart port on the TV (it should be numbered usually AV1..AV2..etc..)
Then you just need to switch to the appropriate AV channel on your TV
hope this helps.....
also check in your TV manual if the av socket you are connected to is an input or an output.
Posted on Oct 11, 2007
SOURCE:
Hooking up dvd player rca type and tv just keeps showing... no signal
Hummmm... the YELLOW RCA should be your VIDEO cable and have VIDEO signals.
Are you SURE your TV is set to the CORRECT "INPUT" SETTING? And DO YOU hear and audio>?
Anthony
Apr 17, 2018 | LG Televison & Video
Dvd conection
Check the settings on the dvd it may be set for headset only or audio off. Have u tried putting in headphones to see if you can hear anything?
Jul 11, 2010 | XO Vision XOD1735 Car DVD Player
I AHVE A HD PHILIPS TV ,IHAVE ABSOLUTLEY NO SOUND ON THE STANDARD TV ,I ONLYHAVE SOUND IF I PLAY A DVD MOVIE. RIGHT NOW THE SUPERBOWL IS ON AND I CANT HEAR A THING.PLEASEHELP.
when you play a dvd, do you have to select aux, or video channel to play this ? if so select tv on your remote, not a solution, just an idea.
Feb 08, 2010 | Car Audio & Video
Cant get conneted
make sure that the ethernet cord is plugged in right
Jul 22, 2009 | Sony Playstation 3 40GB System Console
Wireing mess I need to know what the park wire is for
if its a dvd playing cd player it is so you cant watch dvd's while driving. Can be bypassed by just connecting it to the black ground wire. Or to the earth connetion on the back of the radio. Which is usually a screw that srews into a 5mm hole.
Apr 26, 2009 | OEM Systems Car Audio & Video
Help with samsung dvd dx 103
Hi and welcome to FixYa.
Your camcorder records videos in MPEG2 format. You need that codec installed in your pc to play the videos. You can find that here.
http://www.free-codecs.com/download/stinky_mpeg_2_codec.htm
Let me know if you have any other questions, or if you need more help.
Rob
Mar 17, 2009 | Samsung SC-DX103 DVD Camcorder
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Can't hear right speakers
ok...got it..so..is your player have a stereo option for the DVD..can you make sure that's selected?
Mar 17, 2008 | Jensen VM9020TS Car DVD Player
Dvd function not working
PS is progressive scan, unless you have the player hooked up to a HDTV on its component inputs it wont play video, you need to locate button either on the front of the unit or on the remote for the Progressive Scan, this might be a good thing to look up in the manual as I dont know much about this unit.
Jul 07, 2007 | Daewoo DV-6T955B DVD Player/VCR
kawasaki 1152 System Logo
108 people viewed this question
Top kawasaki Audio Players & Recorders Experts
Marvin
Marvin
Tom Chichester
Are you a kawasaki Audio Player and Recorder Expert? Answer questions, earn points and help others
