seems my drain is plugged on my dishwasher it is the magic chef 4500b unit and i now have water all over my kitchen floor. i cant seem to find the product du4500b so i entered the du2000 , either way there is water on my floor and about 4 inches of water in the bottom of the dishwasher
Ok there are several problems this can be caused from... 1. there is usually a float device (I'm not sure about this model) that floats up and turns the water flow off when an appropriate amount of water is injected into the DW...sometimes these get gummed up with soap and gunk...look in the DW and see if such a device is present (usually front right side) if so you should be able to lift it and inspect it for gunk...if no gunk is present push the float up and down and listen for a "clicking" noise and make sure the float returns to its up position (spring loaded) and after you have evacuated the water turn the DW on and start to fill see if the water shuts off automatically after it has filled (this is most likely your problem)..... 2. Another problem is that often if dishes are not rinsed and lots of food has accumulated around the bottom of the DW..it can obstruct water from draining and since the drain cycle is on a timer...all the water will not drain out and during the next cycle...(and usually only if the float is not functioning) it will overflow. So the odds are you are going to have a float problem. 3. Also in my 35 years of appliance repair I have seen maybe 2 DW drain lines clogged and usually it is right where they attach to the washer...due to the aforementioned food accumulation. Turn the washing machine timer through its cycle from wash to rinse or whatever is necessary to get it to drain...you should here a door or valve click open and water running into the garbage disposal side of the sink...if this is the case the drain line is good.
Hope this helps...get back to me if not....The Fang
where is the drain in a Magic Chef DU2000v dishwasher. there is water inthe bottom and I can see...
(More)
where is the drain in a Magic Chef DU2000v dishwasher. there is water inthe bottom and I can see where it is.
I could put a chair against the door for a while and it would come on and stay on, now it will do...
(More)
I could put a chair against the door for a while and it would come on and stay on, now it will do nothing
After drain cycle water remains in bottom of dishwasher magic chef. Have checked water flow from...
(More)
After drain cycle water remains in bottom of dishwasher magic chef. Have checked water flow from drain pipe into a bucket and that seems to be ok.
Dishwasher is draining, have checked the flow into a bucket, but leaves about 2 inches of water in...
(More)
Dishwasher is draining, have checked the flow into a bucket, but leaves about 2 inches of water in the unit which we have to bail out manually.
