Question about Canon BJC 80 InkJet Printer
Time consuming I have a BJC-80 printer running on a xp laptop through a parallel to usb cable. Everytime I print something it takes around 5 minutes for the printing to start, why? Other printers through usb to usb don't have this problem with my laptop...any suggestions? Thanks
  • 4 more comments
  • Cardmoney Aug 24, 2007
    I can't seem to find a xp driver on the canon site for the bjc-80. Does anyone know where I can locate it?
    Thanks
    When I double click on 'manage' no printer shows up in the list, I feel like a rookie here.
  • Guss123 Apr 03, 2008
    I'm using Windows XP. Laptop recognizes Canon BJC 80 printer. Printer is able to print it's own data sheet. But I can not get anything to print from the laptop to the printer. Does anyone know how to work this out?
    Thanks
  • Anonymous Apr 03, 2008
    my windows xp has no driver for canon bjc -80, tried to download free driver without success
  • limbmag Jun 27, 2008
    Why does it show as "unrecognized" on 1 computer but it prints from my roommate's computer, both using windows xp?
  • kathonea Sep 07, 2008
    I just connected my printer to my new laptop. I had to buy a adaptor for the printer so it would plug into a usb port. Now, my computer doesn't recognize that there's a printer attached, nor does it print anything. What do I do??
    Problem Solver:
  • 18 Answers
I've been using a BJC-80 for ten years, 1998-2008. I replaced the waste ink pad this year.
Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}USB to Parallel conversion requires translation by XP and Vista's'hardware interleave' software as well as the USB device manufacturers driver.The software package just doesn't work well with older peripherals that uselegacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPTprinter port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Cardadapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so manycomplaints about USB to Parallel or Legacy Serial adapters. Printingis Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista,and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5Mbps.
The BJC-80 and the BJC-85 have the same print speed. TheBJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps.Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IRport, the XP print spooler has problems with it, and can hang if printing morethan one page, and especially with more than one document. It will not scan.
I use IR for printing single pages onlywith either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers,and they all work perfectly as a hot-pluggable, instant LPT and/or LegacySerial port for my laptops.
After installing the PC Card driver, check Device Manager for the LPT portnumber. Install the printer manually from the list of printers, and select theproper LPT port.
Most laptops have two PCMCIA slots. If you change slots, theadapter card driver may reinstall, and assign the next available LPT port,LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridgewithin XP or Vista.
Within Vista, set the Canon ISScan software to run inWindows 98 compatibility mode, to allow use of the TWAIN driver.
Prices obtained with eBay searches.
Posted on Oct 05, 2008
Same thing happened to me when I got new xp computer 5 years ago, I read to use bjc 85 driver & it worked great. Now I have a new laptop w/vista & can't get it to work!
Posted on Jul 20, 2008
    Scholar:
  • 70 Answers
You do not need an additional driver for xp.
go to Control panel, then printer-fax, click add printer. Then follow the instruction. Choose BJC80. But usually it comes automatically if you plug in the printer.
Posted on Jan 09, 2008
  • augusta surijah
    augusta surijah Jan 10, 2008
    I had the same experience about using usb - parallel adapter for BJC80. The usb-parallel adapter are different depend on the producer. So, before buying the cable, search first if it supports BJC80. Seems the generic one does not support BJC80.
    The computer (Windows XP) directly recognize my BJC80 in the USB port, and installed the driver automatically. But I have to wait 5 minutes just to print one sentence in Microsoft Word.
    President:
  • 317 Answers
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Posted on Aug 23, 2007
  • Peter Burns Aug 24, 2007
    Another thing you could try is to right click My computer, then select manage. then double click device manager. Under printers, select yours, right click it, then update driver and allow windows to search for it and install it.
    Is this an old printer? I'm surprised they don't have a driver for it for XP.
How to print from Window Vista to Canon BJC80 printer using USB to Parallel cable
Helen, is the printer correctly installed in laptop? Check if shows under Printers and devices. If not, install and show it as default. Make sure your usb connections are ok.
Mar 19, 2014 | Canon BJC 80 InkJet Printer
I have a Canon BJC 80 InkJet Printer. I have it connected to my laptop using a parallel USB cable. The problem I'm having is that whenever I try to print anything, it will sit there for about 5 minutes...
I could be wrong but it sounds like a communication error between your laptop and the printer, I would check that your Canon is compatible with being connected via a USB to parallel cable. If you're running a network you could install the printer onto a PC that has a parallel connection output and then share the printer. More info can be found at this link.
Oct 04, 2010 | Canon BJC 80 InkJet Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: decoy424@gmail.com
Feb 03, 2008 | Canon BJC 80 InkJet Printer
Slow printing
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Nov 01, 2007 | Canon BJC 80 InkJet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
369 people viewed this question
old marine
old marine
