Question about Frigidaire FAS156N1A Air Conditioner
Window AC takes spells on cooling?
Our 1 year old Frigidaire window ac has started taking spells of not cooling. I though it was due to our high temperatures, but I am not sure that is the case. It will cool, then by noon time it only blows out air like a fan. It will go back and fourth with fan air and then cold air. We have cleaned the filter recentally and doesn't seem to have helped. We also have a smaller room ac, which is much older, and it has been doing fine, so that is why I am confused about it just being too hot. It has the energy feature, but we keep it on constant cool. Any help would be appriciated!
  • Lissajayne05 Aug 28, 2007
    Thank you for the advice. We took the AC unit out of the window, and my husband throughally cleaned it. It seems to be working much better now.
  • 50 Answers
One thing to check is to make sure the evaporator and condenser coils are clean. Any dirt here will short ccle the compressor.
Posted on Aug 25, 2007
  • Anonymous Aug 31, 2007
    Glad to be of help.
    Thx,
    RepairUSA
SOURCE:
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
Popping/clicking noise
for window type ac, it must be positioned on level, to avoid flexing it's case.
Jun 04, 2013 | Haier Heating & Cooling
Temp reading goes up instead of down when my 1 year old Haier window AC is turned on
You must call to the company supplier for to claim this problem.
Normally the control thermostat can be defective. Contact customer support they have 24 hours online service.
God bless you
May 09, 2012 | Haier Heating & Cooling
I have an LG window air conditioner that's about 2-3 years old. The cooling function doesn't work. It just blows air and makes the air conditioning sound. How can I fix it? Is there a cheap...
Hello, this could be a problem with the thermostat on you ac and not turning on your compressor or the unit has no revrigerant in it. Here is a links to where you can buy window ac's online. http://www.amazon.com/Frigidaire-FAX052P7A-Window-Unit-Conditioner/dp/B000Q7GSHQ. You can also try sears they might be able to install a window ac for you.
May 13, 2011 | Heating & Cooling
Frigidaire AC 10,000 btu-not cooling very well
Make sure the filter is clean. Take the unit outside and get some coil cleaner and cleant the coils. You'll have to remove the casing. Also,rinse it from the inside outwards.
Jul 29, 2010 | Frigidaire FAC107P1A Wall/Window Air...
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
My LG 1 ton window AC is in running (as the sound of running compressure is there)but there is no cooling effect inside, nor any heat in the outside fins.The ac is only 2 years old. Is it due to leakage of...
Hi, if you can hear the compressor running and its blowing room temperature air only, yes, if the air from the out side condenser coil is not hot, I would say you are low or almost out of freon. This is something you will have to call a tech out to find the leak and recharge. Even though it is only 2 years old, they can get leaks due to vibration. I don't know what you paid for it, but it will cost some $$$$ to have someone come out. It may be cheaper to replace it, as the leak could be in one of the coils which it wouldn't be worth fixing. Let me know on what you decide and if you need my help.
Sincerely,
Shastalaker7
PS Take a water hose and wash the out side coil off. do not bend the fins. See if it starts to cool then. If not, you are low on charge.
Apr 17, 2010 | Heating & Cooling
I HAVE 1.5TON AC IE WINDOW a\C IT CONSUMES MORE
Air conditioners compressors are high starting torque motors , although it uses 15 amps running , it takes perhaps 3 times that briefly to start a compressor. Thats why in the old days the lights dimmed while the ac started etc. Air conditioners are designed to operate at 95 outdoor/ 80 indoor. The design temps are 80 air into a 40 coil gives 60 supply temp, for a 20 temp drop with each pass.
The outdoor coils are 30 above ambient so the hot outdoor air will still be cool in relation to the hot refrigerant gas and remove heat to condense it back to a liquid. Since the pressures and temps are according to ambient there isnt any way to not have the amp draw increase with load.
That said check the breaker for age and replace if not pretty, check all connections for tightness, consider dedicated circuit.
Aug 25, 2009 | Heating & Cooling
CARRIER WINDOW AC IN INDIA
clean the drain system, find the restriction
Apr 21, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Frigidaire FAS156N1A Air Conditioner Logo
396 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
