Question about JVC AV32F577 32" TV
Black on lower half of screen
A black rectangle appears on the lower half of the screen. If I touch any button it goes away for about 10 seconds and returns. It doesn't appear on local channel 27 or on Videos, and on some commercials. Help me!
  • 1 more comment
  • Jeddis Aug 26, 2007
    I tried the front lock part and ended up locked out of several stations with the black space still there. My son-in-law is coming over (soon, I hope) to see about the cable part and since the set was his before maybe he has a code to unlock the child proofing. Ill let you know. Thanks so much for the help.
  • Jeddis Sep 04, 2007
    You answered my problem of black rectangle. While following your instrucrions in the menu my son-in-law discovered the "closed caption" sign said it was on, but it was not showing on the screen. He turned it off and the rectangle disappeared. But after he left I discovered the child lock is now on and no way to know the code to turn it off. Can you help agaain?
  • Jeddis Sep 08, 2007
    My son-in-law found the Instruction book for my TV and came and figured out how to delete the child lock. Hurray! I can watch Jon Stewart and Stephen Colbert!
    New Friend:
  • 76 Answers
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Posted on Aug 24, 2007
SOURCE:
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
Black Box in the lower portion of the screen will not disappear
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
Mar 25, 2010 | JVC AV-32120 32" TV
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Jan 20, 2009 | Disney 13" TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Large Black rectangle on bottom half of screen
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Jun 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Black rectangle
If the black rectangle is in the middle'please check to see that the closed caption is not activated.If not please provide the location of the rectangle.
Jan 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
JVC AV32F577 32" TV Logo
85 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
