Question about Jenn-Air JS42CSFXDA Side by Side Refrigerator
Panel installation Are there any directions/ideas for panel installation on the refrigerator? Also, is it possible to put on standard panels and if so where can I get them?
    Problem Solver:
  • 4 Answers
Re: panel installation
Jenn Air has panel frame kits which you should be able to track down fairly easily. If that doesn't work, depending on how skilled and ambitious you are, there isn't a lot of rocket science to a frame kit. You might consider another manufacturer's frame kit, even if you have to cut it down (as I said, depends on how ambitious & skilled you are). The frame kits usually just have screws that attach to the sides of the doors. Most of those frames allow for about a 1/4" slide in material. You can either build finished panels that slide right in, or make up a panel that attaches to the 1/4" material, so that it overlaps & completely covers the frame material.  If that is all too complicated for you, contact your friendly neighborhood cabinet shop. A custom shop should do those things all the time. Hope this helps.
Posted on Mar 28, 2008
0 characters
3 Points
Good afternoon friend, thanks for your inquiry!
From what you are describing it sounds like a possible issue with your control panel, UIB (User Interface Board), or control panel. The control panel and UIB would help to distribute any power being received into your refrigerator. The power cord would be the origin of where the power would enter into your refrigerator.
I would recommend putting the refrigerator into a different outlet to see if that would start up power or check to verify the household breaker has not been flipped. I hope this is helpful to some degree. -Matt
Oct 03, 2014 | Electrolux Refrigerators
Removing LG refrigerator control panel
Put your model number into a or go to there should be a video on either site showing you how to remove that panel
Mar 02, 2014 | Refrigerators
Rm2862 willnot comeon at all,frot panel does come on , no blown fuse Lp turns on the heather but unit will not cool
If you fridge is level, and the rear coils of the cooling unit are warm then you more then likely need a replacement cooling unit. If you do, we can help. We are Arcticold Refrigeration. We specialize in the manufacturing of New Replacement Cooling Units for Dometic & Norcold RV Fridges. Our cooling units are direct replacements of the factory units. In most cases the cooling units can be changed in a couple of hours. Arcticold cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. We also offer 7 day a week free tech support 1-888-782-6665 Our cooling units are available throughout North America. Don't hesitate to give us a call or visit our web site. ArctiCold Refrigeration We keep it cold f926e66c-02f3-4d45-9004-f68d1864e268.jpg
Dec 26, 2013 | Dometic RM2852 Refrigerator
Same problem ice maker stoped working model#106.5360202
Yea then check for ice in the water lines, if no jump the water valve direct if you get water then its the ice maker...
Jun 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Aug 17, 2008 | LG LRFC25750 Refrigerator French Door
Refrigerator smell
Defrost water tray may be located in the back of the refrigerator behind a removable panel. If you remove the panel make sure you re-install it.
Jun 09, 2008 | Sub-Zero 690 Side by Side Refrigerator
Active Smart Temperature Control Panel - Red Light
it is possible that it is the cooling regulator that is having a fault. The F&P customer service centre will / should be able to help diagnose this over the phone and give you a much better idea what u should do.
Nov 19, 2007 | Fisher and Paykel Active Smart E522B...
Jenn-Air JS42CSFXDA Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
