Question about Microsoft Windows XP Home Edition
Add/Remove Hardware Window Won't Go Away
Got it to check for something, but it's been going for TWO HOURS!!! No "X", no button, nada.... my mom is not computer savvy and thinks that shutting down a computer will cause all of her stuff to go (becuase her "calculator does that"...oh boy) anyway to do this without giving my mom a heart attack?
  • docstrange Aug 23, 2007
    yeah i did CTRL ALT DELETE, and nothing....
    when i did that it was on for like a second and then it dissapeered. And it's still running.....
  • docstrange Sep 23, 2007
    never mind then, fixed it me self, simple log off/log on all i needed to do
    Problem Solver:
  • 10 Answers
Ctrl+alt+delete and go to the processes tab and shut down explorer.exe then go to the applications tab and press new task and start explorer.exe. the add/remove window should be gone. If not then you should tell your mom to cover her eyes while you restart :)
Posted on Aug 23, 2007
  • Jacob Van Kley
    Jacob Van Kley Aug 23, 2007
    Hmm that is very interesting. Most likely the only solution is tor restart then. Show this document to your mom http://www.escotal.com/memory.html) and explain to her that anything she puts on the hard drive is there permanently (even if deleted) and that if you restart the computer her files will all still be there.
SOURCE:
Rear passenger window goes down with the switch but won,t go up, also from the driver main panel the window won,t go down but will work on the up button
Sounds like you have issue with the push button controls for the window. I really don't think I had to say it. If you remove the door panels and check it out you may find, rust broke wires, bad connection some simple problems which need a better visual look. If a window goes down but not up. It should not be a fuse, relay or power issue unless the connection is a problem.
Aug 07, 2017 | Cars & Trucks
The 2003 Concorde my mom has won't start right away sometimes after it's turned off not because of anything mechanical but something with the security i was told. Any thoughts on how to turn t
Typically dealers are the only people who can work with the security systems on cars. If it is a factory security system, calling a dealer would be your best option. If it is aftermarket, call the company that installed it. If you have a mechanic you trust, you are free to ask them for advice, but typically mechanics will refer you to a dealer for security system issues.
Oct 24, 2012 | 2003 Chrysler Concorde
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
My netbook tells me to reset my wireless adapters Im trying to get wireless internet. It tells me there a network to connect to but it won't let me connet to it.
Hi
For uninstall the driver of Wireless adapters follow the mention below instruction.
  • Go to the control panel and click the Add & Remove program.
  • You see the install driver list you have to select the your wireless adapters and click the remove.
  • After few min you driver is uninstall the window show you driver uninstalling finish.
  • Then reboot you computer.
  • After rebooting you get New hardware found window in start up the notebook,take the wireless driver installation CD and put the notebook CD-ROM.
  • And new hardware found window click next, automatic he install the driver in CD, after complete the driver installation reboot you laptop once more.
  • Now you wireless adapter connect to Internet and your problem will solve.
If my answer solve you problem then give me 4 thum
Thanks
Aug 24, 2011 | Acer Aspire One D255 Netbook
My drivers side window won't stay on the track when I lower it. It.s NOT powered. Is there something inside that I can't see keeping me from getting this done?
are you talking about the window going crooked when lowering it if so then there is a clip that mounts to the side of the window that keeps it in the track so it won`t do this.they sometimes break and you can buy the part and install it just be careful when installing so the window won`t break.if its the track at the lower edge of the window this is a pressure/glue type fit and the track will need to be cleaned,pushed together a bit and use a window glue and install the window into the track and let it sit for a couple of hours before trying it.
Jun 30, 2011 | 1989 Oldsmobile Delta 88
How do I find a fuse diagram for a 2001 Toyota Celica the right front passenger window will not go up or down
Go to a local repair shop that has a Data Base
& have them print what you need
Check all fuses,don't need a diagram for that
If any window works,it won't be the fuse
If the fuse is blown,replacing it won't fix anything
It will blow again,
So,you will need to check switches first,then remove
the door panel to access the window motor or
window regulator.
May 23, 2011 | Toyota Celica Cars & Trucks
Printer will not respond to laptop
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side. Please refer the below picture to view the port on the printer.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:\WINDOWS\I386 folder.
  • Remove and reconnect the printer.
Jan 27, 2011 | HP PSC 1350 All-In-One Thermal Printer
I changed my window from window vista business to window xp , now i have window xp. but after installed it i lost the sound of my laptop compaq presario c700. i lost audio and sound device,...
you just go to control panel add/remove programm then
Click the "Add/Remove Windows Components" button on the left side of the window to display a list of available components.
Highlight any available component you want to install like sound. If the "Details" button is displayed, click to view sub-components. Check the box next to the "Sub-Components" or "Components to Add" options.
Click the "Next" button to complete the configuration wizard and the "Finish" button to close the Windows Components Wizard
Oct 22, 2010 | Computers & Internet
No audio driver can be installed in my sytem
I need audio dirver because my system was not found sound.
101 GGc
Intel D945
Oct 08, 2009 | Intel D845GVSR Motherboard
Hi, I have added a USB 2.0 4 port PCI card to my PC, when I run the support disc to add the driver it says no hardware found. All the instructions say are plug in the card and run the disc, is there...
Dear Friend,
If you have windows xp, generally when you add new hardware. Windows does show found new hardware window, where you can select the driver for your new hardware.
Go to control panel=> Add new hardware & then select the appropriate drivers for your card.
Hope this solves your problem.
Jul 28, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
192 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
