Question about Kenmore 16226 Grill
Frozen valve teh open/close valve on the propane tank will not budge. How can I fix this so I can grill again?
  • ctyank Aug 23, 2007
    I have tried turning it both ways, it will not budge
  • Anonymous Mar 16, 2014
    gas flows when attaching hose with propane tank valve closed
Never bang on a propane valve for ANY reason...ever. a NEW tank is just too easy to get ahold of. For 29 ro 30 bucks, you can get a full tank at many grocery stores. WAY cheaper than a trip to the hospital or worse.
Jeff
Posted on Jan 27, 2008
    Problem Solver:
  • 10 Answers
I had this problem recently. Try turning the valve the other way (seems odd, i know). This worked for me. Also, if this doesn't work do not do anything too drastic on it because it can explode.
Posted on Aug 23, 2007
  • Jacob Van Kley
    Jacob Van Kley Aug 23, 2007
    It could be that a recent temperature change in your area has caused this. I would recommend buying a new propane tank if there isn't too much propane left in this one.
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
Cannot get and flame.see spark from starter new tank
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
Jul 15, 2014 | Weber Grilling
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Weber spirit won't get hotter than 300. What's wrong?
Jun 19, 2014 | Weber Genesis Silver C Grill
My weber genesis E 330 thermometer never goes higher than 400 degrees F Why?
Jun 04, 2014 | Weber Genesis Silver B Grill
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
One burner barely lights; others don't light at all.
This is a common problem with grills purchased after 2001 or with a full propane tank with a lot of pressure in it. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
Ben Gaetani
Tanks 2 You Propane
Feb 23, 2010 | Weber Genesis Silver B Grill
The valve on my propane tank won't turn off or on. grill lights
suggest you take the tank and trade it in for a new one with one of the propane companies like blue rhino. it's about $15 to $20 and you get a brand new full tank.
Jul 16, 2009 | Grilling
Kenmore 16226 Grill Logo
367 people viewed this question
Top Kenmore Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
