LG WM1812C Front Load Washer Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine overfilling lg laundry washer wm1812cw error code fe
Anonymous
Level 2:
  • Expert 144 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Answers
144
Questions
0
Helped
82966
Points
350
You need to check the pressure switch and tube wich you can access from the top of the machine with the top removed. the tube is a rubber pipe which may have fallen of the switch or pressure chamber connection. cheers
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
2answers
FE code on LG washer.
The FE code is an excessive water supply if the water is continuously running into the machine it may be due to a failing inlet valve or stuck float switch since you mentioned the drain pump filter being changed it could be that the old filter was restricting the flow.
Error code FE what to do
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
On my LG tromm washer has an error code FE, what is the solution to this problem or how do i get it fix???
3answers
Error FE on a LG WD 1274FHB what does it mean?
How do i reset FE code on wm2016cw washer machine
Oct 16, 2014 • LG WM2016C
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Display code FE... what needs to be done
FE in an over fill error. (the pump should automatically come on to drain water) If the machine is not overfilling, check the thin hose that goes to the water level switch. If it is overfilling you will either need to replace the inlet water valve if it is filling with no power to the vavle, or the main control board if it is receiving power in the FE condtion.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
