Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon IPixma 4200 Won't Power On (occassional)
Printer works fine when it works but every several months or so, it will fail to power on even though there is power at the outlet...I have even checked with a volt meter at the printer end of the power cord. The switch doesn't light even when held in. This situation may last for anywhere from a few hours to several days. Anyone ever hear of this problem? How can I open the case to access the back of the switch? (Case has no screws or other fasteners)
    Sergeant:
  • 390 Answers
Go on an elimination hunt. Try connecting to a new power outlet altogether. If no go, try turning off and removing all cords, usb etc, reconnect. Then try uninstalling and reinstalling the printer to see if this corrects it. Post agian if no good.
Posted on Aug 25, 2007
Why isn't it powering up and all lights are staying on?
Check all the cables and make sure that they are plugged in tightly. After that I can't help you without more information.
May 11, 2015 | Siemens Speedstream 4200 Modem
Why won't the top burners light or perform at 100% on my frigidaire glgf377ase?
sounds like the gas supply line to those burners are clogged. a needle or toothpick should unclog them with no problem
Jul 14, 2012 | Frigidaire Kitchen Ranges
When trying to transfer photos printer was fine, then transferred everything on its memory even though we already had it then kept asking to load memorycard when it was already in wont acknowledge any
Power off the printer and wait for 2 minutes.
Power the printer back up and access it thru the PC controls software and try to print something that way.
if this is no good , then I would access the printers web site at ;
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Jan 13, 2012 | Canon MP490 InkJet Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
Juicier will not work at all
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
May 07, 2010 | Champion G5NG853S Household Juice...
Garmin nuvi 765t won't power up
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your 765T is listed as a $99 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 16, 2010 | Garmin n?vi 765T Car GPS Receiver
Canon PIXMA iP4200 InkJet Photo Printer Logo
129 people viewed this question
old marine
old marine
